I’ve been trying to make a qubes 4.1 archlinux template (and others) for a while now but I always get the same response. I will make it past the set up just like the documentation website(selecting 4.1 instedo of 4.0) and then I will make it past ‘make install-deps’ ‘make get-sources’ and when I do ‘make qubes-vm’ I get.
scripts/test-sane-mount: line 10: ./test-dev-null: Permission denied
*** ERROR ***
*** Cannot create chroot because the current filesystem is mounted as nodev. ***
*** Build Qubes on a different filesystem, or run ‘make remount’ to remount ***
*** /home with dev option.
I will do ‘make remount’ (just I have nothing better to do) and then It will go for a while untill I get:
Currently installed dependencies:
createrepo_c-0.15.11-1.fc32.x86_64
debootstrap-1.0.123-1.fc32.noarch
dialog-1.3-24.20191210.fc32.x86_64
dpkg-dev-1.19.7-5.fc32.noarch
git-2.26.2-1.fc32.x86_64
perl-Digest-MD5-2.55-440.fc32.x86_64
perl-Digest-SHA-6.02-442.fc32.x86_64
python3-sh-1.13.1-1.fc32.noarch
rpm-build-4.15.1-3.fc32.1.x86_64
rpmdevtools-8.10-10.fc32.noarch
–> Archlinux dist-prepare-chroot (makefile):
–> Checking mounting of dev/proc/sys on build chroot…
–> Synchronize resolv.conf, in case it changed since last run…
-> Building vmm-xen (archlinux) for archlinux vm (logfile: build-logs/vmm-xen-vm-archlinux.log)
–> build failed!
qubes is up to date
:: Starting full system upgrade…
resolving dependencies…
looking for conflicting packages…
Packages (1) libcap-ng-0.8-1
Total Download Size: 0.04 MiB
Total Installed Size: 0.10 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n]
:: Retrieving packages…
downloading libcap-ng-0.8-1-x86_64.pkg.tar.zst…
checking keyring…
checking package integrity…
loading package files…
checking for file conflicts…
:: Processing package changes…
upgrading libcap-ng…
:: Running post-transaction hooks…
(1/1) Arming ConditionNeedsUpdate…
–> Archlinux dist-package (makefile)
–> Building package in /home/user/qubes-src/vmm-xen
sudo BACKEND_VMM=xen chroot “/home/user/qubes-builder/chroot-vm-archlinux” su user -c ‘cd “/home/user/qubes-src/vmm-xen” && cp archlinux/PKGBUILD* ./ && env http_proxy="" makepkg --syncdeps --noconfirm --skipinteg’
==> Making package: qubes-vm-xen 4.14.0-5 (Thu Oct 15 21:47:24 2020)
==> Checking runtime dependencies…
==> Installing missing dependencies…
sudo: effective uid is not 0, is /usr/sbin/sudo on a file system with the ‘nosuid’ option set or an NFS file system without root privileges?
==> ERROR: ‘pacman’ failed to install missing dependencies.
==> Missing dependencies:
-> python
-> bridge-utils
-> python-lxml
-> lzo
-> yajl
==> Checking buildtime dependencies…
-> wget
-> git
-> bin86
-> dev86
-> iasl
-> yajl
-> pixman
==> ERROR: Could not resolve all dependencies.
make[2]: *** [/home/user/qubes-builder/qubes-src/builder-archlinux/Makefile.archlinux:121: dist-package] Error 8
make[1]: *** [Makefile.generic:191: packages] Error 1
make: *** [Makefile:227: vmm-xen-vm] Error 1
I have looked all over the internet and I don’t know what to do because I have Emailed the qubes user mailing list and got no response. If anyone can help that would be grate! thank you in advance!
