Hi there,
Not being able to upgrade to Quebes-4 (hardware compatibility) Iwas stuck with Fedora 28 & I had to move on. I’m on Fedora-34 with a backup of few of my Qubes machines containing some data I need to recover. The Qubes disks were encrypted & I’ve obviously the password. My problem is how to open (mount or …) those machines.
Is there a way to open them outside of the Qubes OS based on their format?
Thanks
See this:
For a Qubes 4.0 backup see here: Emergency Backup Recovery (v4) | Qubes OS
Thanks. I’m going to give it a try.
I gave it a try and it didn’t work. I backed up the VM to a hard disk and this is the backup I’m using. Basically I think the file is not tampered. Maybe corrupted (wonder how it could be).
I used both passwords, the user one and the one to encrypt the disk. None worked. Is there anything else I can try?
