I was poking around in the Software menu selection for the while in the template for fedora 36. Was started. Banged on the Install button but nothing happens. Are these install button active or is there something I need to set?
Thanks
Thanks
Hi @Peregrine, the process of installing software in templates is documented here:
Unfortunately, the Fedora GUI tools do not work well with the Fedora
templates. These have no network connection, and use a proxy reached via
qrexec. The Fedora tools don’t work in that situation.
