before opening an issue on the issue tracker, I want to discuss it here.
R4.3.1, XFCE:
I’ve noticed that the window border colors for labels “red” and “orange” are hard to distinguish. Someone else has confirmed that issue even on a color-managed monitor.
The colors are (picked from the middle of the title bars, using HSV color space model, rounded values):
“red” is: hue = 7 degrees, saturation = 68%, value = 100%
“orange” is: hue = 30 degrees, saturation = 73%, value = 99%
“yellow” is: hue = 53 degrees, saturation = 83%, value = 97%
So:
“red” is red towards orange.
“orange” is orange (in HSV hue) but more saturated than red.
“yellow” is yellow towards orange.
Due to 1) and 2), red and orange seem to be hard to distinguish.
In order to solve this, I suggest:
“red” should be more red (hue = 0 degrees) and more saturated (around 80%).
“red” could be a little bit darker (value around 80%), but this could result in a less readable window title.
“orange” should now have a greater distance to “red”.
AND/OR:
“yellow” should be more yellow (hue = 60 degrees); this makes more distance between “orange” and “yellow”.
now, “orange” could be made a little bit more yellow (hue about 35 degrees).
Note that the qube label colors in the settings are slightly different from the actual window border colors! (Qube label color “green”, for example, is more blue than its corresponding window border color (which is rather lime).)
What do you think?
Can you confirm this issue?
What are your suggestions?
Same HSV values look different on different devices. For objective comparison color should be measured in CIELAB color space.
Generally, orange/red is a bad choice for distinguishing colors due to human visual anatomy as also seen in its a/b values which are very close to yellowish/red. IMO, orange should be replaced by magenta or cyan which are more a/b distant and easier to the eye. Cyan is much easier to distinguish from blue and green than orange from red, even when using simple maximum RGB values (0, 255, 255). Gray should be replaced by white.
RGBCMYKW - what xfce4-terminal --color-table displays - has stood the test of time.
I wonder if the color values could be implemented in a way that lets the user adjust them? The color names could stay the same but the user would then be able to choose color values that are easy to distinguish for them. That may especially be helpful to people with color blindness.
You can add your own colors, and then you need to change your existing qubes to use those colors, but I don’t think customizing the existing color is a good idea. What programs normally do is allow the user to choose a color scheme/palette, to guarantee that colors behave well for their purposes.
Like @dhimh, I also wondered if the user could adjust the color, depending on the screen. But having more colors could also help: Just don’t use the colors that don’t work for you (due to the screen or color blindness).
