Hey there,
I’ve several Qubes that shall autostart and have a block device assigned.
These Qubes won’t, successfully, autostart.
Regarding the block device.
I have a lvm thin pool which also is host to the qubes storage itself. Within I created LVs and assigned them static device mapper IDs, therefore the 410 is always valid.
After I logged in, lvs are active and I can manually start the Qube.
Other Qubes without such assigned block devices autostart just as expected.
Obviously I could try creating an overwrite to the specific qube autostart services but that would miss the point of switching the autostart behavior within the qube config.
Any ideas or leads ?
