QSB-116: Multiple Xen issues (XSA-500, XSA-505, XSA-506, XSA-507)
We have published Qubes Security Bulletin (QSB) 116: Multiple Xen issues (XSA-500, XSA-505, XSA-506, XSA-507). The text of this QSB and its accompanying cryptographic signatures are reproduced below, followed by a general explanation of this announcement and authentication instructions.
Qubes Security Bulletin 116
             ---===[ Qubes Security Bulletin 116 ]===---
                              2026-07-28
User action
Continue to update normally [1] in order to receive the security updates
described in the "Patching" section below. No other user action is
required in response to this QSB.
Summary
On 2026-07-28, the Xen Project published the security advisories below.
XSA-500 [3] "grant-table: type confusion in grant-copy":
| When grant-copy operations are processed, the respective grant may or
| may not already be in use by another operation (a mapping or another
| copy). For all copy operations the referenced guest frame is looked
| up. When another operation is already active for the grant (the grant
| is "pinned"), what is being supplied back to actually carry out
| permission checks and copy operation may not be consistent: The
| permission check may be carried out on a page different from the one
| involved in the copy.
XSA-505 [4] "evtchn: Race between FIFO expand and reset":
| The EVTCHNOP_expand_array hypercall checks for whether FIFO event
| channels are enabled, but without holding the correct lock. It can
| race with EVTCHNOP_reset, resulting in deferencing a NULL pointer.
XSA-506 [5] "correct buffer checks for DM_OP hypercalls":
| Parts of the DM_OP handling code assumes the caller has provided the
| required number of buffers for the given operation without any
| checking being done. As a result, certain operations might access
| stack rubble as structures are possibly uninitialized.
XSA-507 [6] "PoD: Don't try to reclaim special pages":
| A guest started with Populated on Demand enabled (PoD) can attempt to
| reclaim pages which aren't regular guest RAM. This can cause
| corruption of memory management state in Xen.
Impact
XSA-500 and XSA-507: A malicious qube may be able to compromise
Qubes OS.
XSA-505: A malicious PV qube [7] may be able to compromise Qubes OS. The
same impact applies to stubdomains for HVM qubes [8], but in this case
an attacker would first have to discover and exploit an independent
vulnerability (in QEMU) in order to gain access to the stubdomain.
XSA-506: The stubdomain for an HVM qube may be able to leak data from
other qubes in the system. In order to exploit this vulnerability, an
Affected systems
XSA-500: All systems are affected.
XSA-505: Systems with either PV qubes or stubdomains for HVM qubes (or
both) are affected, but the vulnerability is easier to exploit on
systems with PV qubes. In the default Qubes OS configuration, there are
no PV qubes, but sys-net and sys-usb are HVM qubes that have
stubdomains. This means that the vulnerability is more difficult to
exploit in the default Qubes OS configuration, but if a user has
manually created PV qubes in a particular system, the vulnerability will
be easier to exploit on that system.
XSA-506: Systems with untrusted HVM qubes are affected. In the default
configuration of Qubes OS, sys-net and sys-usb are HVM qubes and are
considered to be untrusted.
XSA-507: Systems are affected if they have qubes that are included in
memory balancing but that don't advertise memory hotplug support. This
includes malicious HVM qubes with memory balancing enabled, as well as
templates and standalones that use in-qube kernels and that have memory
balancing enabled. The default Qubes OS configuration is not affected,
nor are commonly-used HVM qubes like Windows, since they don't have
memory balancing enabled.
Patching
The following packages contain security updates that address the
vulnerabilities described in this bulletin:
  For Qubes 4.3, in dom0:
  - Xen packages, version 4.19.5-2
by the community. [2] Once available, the packages should be installed
via the Qubes Update tool or its command-line equivalents. [1]
effect.
passphrase to new PCR values, as PCR18+19 will change due to the new Xen
binaries.
Credits
See the original Xen Security Advisories. [3][4][5][6]
References
[1] https://doc.qubes-os.org/en/latest/user/how-to-guides/how-to-update.html
[2] https://doc.qubes-os.org/en/latest/user/downloading-installing-upgrading/testing.html
[3] https://xenbits.xen.org/xsa/advisory-500.html
[4] https://xenbits.xen.org/xsa/advisory-505.html
[5] https://xenbits.xen.org/xsa/advisory-506.html
[6] https://xenbits.xen.org/xsa/advisory-507.html
[7] A PV qube is a qube that is running with virt_mode set to "pv."
[8] For each qube that is running with virt_mode set to "hvm," there's a
    small Xen-internal helper VM running alongside it, in which QEMU is
    executed to provide device emulation for that qube. This helper VM
    runs in PV mode and is called a "stubdomain."
The Qubes Security Team
Source: qsb-116-2026.txt
Marek Marczykowski-Górecki’s PGP signature
-----BEGIN PGP SIGNATURE-----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=vPOZ
-----END PGP SIGNATURE-----
Source: qsb-116-2026.txt.sig.marmarek
Simon Gaiser (aka HW42)’s PGP signature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=BjeB
Source: qsb-116-2026.txt.sig.simon
What is the purpose of this announcement?
The purpose of this announcement is to inform the Qubes community that a new Qubes security bulletin (QSB) has been published.
What is a Qubes security bulletin (QSB)?
A Qubes security bulletin (QSB) is a security announcement issued by the Qubes security team. A QSB typically provides a summary and impact analysis of one or more recently-discovered software vulnerabilities, including details about patching to address them.
Why should I care about QSBs?
QSBs tell you what actions you must take in order to protect yourself from recently-discovered security vulnerabilities. In most cases, security vulnerabilities are addressed by updating normally. However, in some cases, special user action is required. In all cases, the required actions are detailed in QSBs.
What are the PGP signatures that accompany QSBs?
A PGP signature is a cryptographic digital signature made in accordance with the OpenPGP standard. PGP signatures can be cryptographically verified with programs like GNU Privacy Guard (GPG). The Qubes security team cryptographically signs all QSBs so that Qubes users have a reliable way to check whether QSBs are genuine. The only way to be certain that a QSB is authentic is by verifying its PGP signatures.
Why should I care whether a QSB is authentic?
A forged QSB could deceive you into taking actions that adversely affect the security of your Qubes OS system, such as installing malware or making configuration changes that render your system vulnerable to attack. Falsified QSBs could sow fear, uncertainty, and doubt about the security of Qubes OS or the status of the Qubes OS Project.
How do I verify the PGP signatures on a QSB?
The following command-line instructions assume a Linux system with git and gpg installed. (For Windows and Mac options, see OpenPGP software.)
  1. Obtain the Qubes Master Signing Key (QMSK), e.g.:
    $ gpg --fetch-keys https://keys.qubes-os.org/keys/qubes-master-signing-key.asc
    gpg: directory '/home/user/.gnupg' created
    gpg: keybox '/home/user/.gnupg/pubring.kbx' created
    gpg: requesting key from 'https://keys.qubes-os.org/keys/qubes-master-signing-key.asc'
    gpg: /home/user/.gnupg/trustdb.gpg: trustdb created
    gpg: key DDFA1A3E36879494: public key "Qubes Master Signing Key" imported
    gpg: Total number processed: 1
    gpg:               imported: 1
    (For more ways to obtain the QMSK, see How to import and authenticate the Qubes Master Signing Key.)
  2. View the fingerprint of the PGP key you just imported. (Note: gpg> indicates a prompt inside of the GnuPG program. Type what appears after it when prompted.)
    $ gpg --edit-key 0x427F11FD0FAA4B080123F01CDDFA1A3E36879494
    gpg (GnuPG) 2.2.27; Copyright (C) 2021 Free Software Foundation, Inc.
    This is free software: you are free to change and redistribute it.
    There is NO WARRANTY, to the extent permitted by law.
    pub  rsa4096/DDFA1A3E36879494
         created: 2010-04-01  expires: never       usage: SC
         trust: unknown       validity: unknown
    [ unknown] (1). Qubes Master Signing Key
    gpg> fpr
    pub   rsa4096/DDFA1A3E36879494 2010-04-01 Qubes Master Signing Key
     Primary key fingerprint: 427F 11FD 0FAA 4B08 0123  F01C DDFA 1A3E 3687 9494
  3. Important: At this point, you still don’t know whether the key you just imported is the genuine QMSK or a forgery. In order for this entire procedure to provide meaningful security benefits, you must authenticate the QMSK out-of-band. Do not skip this step! The standard method is to obtain the QMSK fingerprint from multiple independent sources in several different ways and check to see whether they match the key you just imported. For more information, see How to import and authenticate the Qubes Master Signing Key.
    Tip: After you have authenticated the QMSK out-of-band to your satisfaction, record the QMSK fingerprint in a safe place (or several) so that you don’t have to repeat this step in the future.
  4. Once you are satisfied that you have the genuine QMSK, set its trust level to 5 (“ultimate”), then quit GnuPG with q.
    gpg> trust
    Please decide how far you trust this user to correctly verify other users' keys
    (by looking at passports, checking fingerprints from different sources, etc.)
      1 = I don't know or won't say
      2 = I do NOT trust
      3 = I trust marginally
      4 = I trust fully
      5 = I trust ultimately
      m = back to the main menu
    Your decision? 5
    Do you really want to set this key to ultimate trust? (y/N) y
         trust: ultimate      validity: unknown
    Please note that the shown key validity is not necessarily correct
    unless you restart the program.
    gpg> q
  5. Use Git to clone the qubes-secpack repo.
    $ git clone https://github.com/QubesOS/qubes-secpack.git
    Cloning into 'qubes-secpack'...
    remote: Enumerating objects: 4065, done.
    remote: Counting objects: 100% (1474/1474), done.
    remote: Compressing objects: 100% (742/742), done.
    remote: Total 4065 (delta 743), reused 1413 (delta 731), pack-reused 2591
    Receiving objects: 100% (4065/4065), 1.64 MiB | 2.53 MiB/s, done.
    Resolving deltas: 100% (1910/1910), done.
  6. Import the included PGP keys. (See our PGP key policies for important information about these keys.)
    $ gpg --import qubes-secpack/keys/*/*
    gpg: key 063938BA42CFA724: public key "Marek Marczykowski-Górecki (Qubes OS signing key)" imported
    gpg: qubes-secpack/keys/core-devs/retired: read error: Is a directory
    gpg: no valid OpenPGP data found.
    gpg: key 8C05216CE09C093C: 1 signature not checked due to a missing key
    gpg: key 8C05216CE09C093C: public key "HW42 (Qubes Signing Key)" imported
    gpg: key DA0434BC706E1FCF: public key "Simon Gaiser (Qubes OS signing key)" imported
    gpg: key 8CE137352A019A17: 2 signatures not checked due to missing keys
    gpg: key 8CE137352A019A17: public key "Andrew David Wong (Qubes Documentation Signing Key)" imported
    gpg: key AAA743B42FBC07A9: public key "Brennan Novak (Qubes Website & Documentation Signing)" imported
    gpg: key B6A0BB95CA74A5C3: public key "Joanna Rutkowska (Qubes Documentation Signing Key)" imported
    gpg: key F32894BE9684938A: public key "Marek Marczykowski-Górecki (Qubes Documentation Signing Key)" imported
    gpg: key 6E7A27B909DAFB92: public key "Hakisho Nukama (Qubes Documentation Signing Key)" imported
    gpg: key 485C7504F27D0A72: 1 signature not checked due to a missing key
    gpg: key 485C7504F27D0A72: public key "Sven Semmler (Qubes Documentation Signing Key)" imported
    gpg: key BB52274595B71262: public key "unman (Qubes Documentation Signing Key)" imported
    gpg: key DC2F3678D272F2A8: 1 signature not checked due to a missing key
    gpg: key DC2F3678D272F2A8: public key "Wojtek Porczyk (Qubes OS documentation signing key)" imported
    gpg: key FD64F4F9E9720C4D: 1 signature not checked due to a missing key
    gpg: key FD64F4F9E9720C4D: public key "Zrubi (Qubes Documentation Signing Key)" imported
    gpg: key DDFA1A3E36879494: "Qubes Master Signing Key" not changed
    gpg: key 1848792F9E2795E9: public key "Qubes OS Release 4 Signing Key" imported
    gpg: qubes-secpack/keys/release-keys/retired: read error: Is a directory
    gpg: key D655A4F21830E06A: public key "Marek Marczykowski-Górecki (Qubes security pack)" imported
    gpg: key ACC2602F3F48CB21: public key "Qubes OS Security Team" imported
    gpg: qubes-secpack/keys/security-team/retired: read error: Is a directory
    gpg: key 4AC18DE1112E1490: public key "Simon Gaiser (Qubes Security Pack signing key)" imported
    gpg: Total number processed: 17
    gpg:               imported: 16
    gpg:              unchanged: 1
    gpg: marginals needed: 3  completes needed: 1  trust model: pgp
    gpg: depth: 0  valid:   1  signed:   6  trust: 0-, 0q, 0n, 0m, 0f, 1u
    gpg: depth: 1  valid:   6  signed:   0  trust: 6-, 0q, 0n, 0m, 0f, 0u
  7. Verify signed Git tags.
    $ cd qubes-secpack/
    $ git tag -v `git describe`
    object 266e14a6fae57c9a91362c9ac784d3a891f4d351
    type commit
    tag marmarek_sec_266e14a6
    tagger Marek Marczykowski-Górecki 1677757924 +0100
    Tag for commit 266e14a6fae57c9a91362c9ac784d3a891f4d351
    gpg: Signature made Thu 02 Mar 2023 03:52:04 AM PST
    gpg:                using RSA key 2D1771FE4D767EDC76B089FAD655A4F21830E06A
    gpg: Good signature from "Marek Marczykowski-Górecki (Qubes security pack)" [full]
    The exact output will differ, but the final line should always start with gpg: Good signature from... followed by an appropriate key. The [full] indicates full trust, which this key inherits in virtue of being validly signed by the QMSK.
  8. Verify PGP signatures, e.g.:
    $ cd QSBs/
    $ gpg --verify qsb-087-2022.txt.sig.marmarek qsb-087-2022.txt
    gpg: Signature made Wed 23 Nov 2022 04:05:51 AM PST
    $ gpg --verify qsb-087-2022.txt.sig.simon qsb-087-2022.txt
    gpg: Signature made Wed 23 Nov 2022 03:50:42 AM PST
    gpg:                using RSA key EA18E7F040C41DDAEFE9AA0F4AC18DE1112E1490
    gpg: Good signature from "Simon Gaiser (Qubes Security Pack signing key)" [full]
    $ cd ../canaries/
    $ gpg --verify canary-034-2023.txt.sig.marmarek canary-034-2023.txt
    gpg: Signature made Thu 02 Mar 2023 03:51:48 AM PST
    $ gpg --verify canary-034-2023.txt.sig.simon canary-034-2023.txt
    gpg: Signature made Thu 02 Mar 2023 01:47:52 AM PST
    Again, the exact output will differ, but the final line of output from each gpg --verify command should always start with gpg: Good signature from... followed by an appropriate key.
For this announcement (QSB-116), the commands are:
$ gpg --verify qsb-116-2026.txt.sig.marmarek qsb-116-2026.txt
$ gpg --verify qsb-116-2026.txt.sig.simon qsb-116-2026.txt
You can also verify the signatures directly from this announcement in addition to or instead of verifying the files from the qubes-secpack. Simply copy and paste the QSB-116 text into a plain text file and do the same for both signature files. Then, perform the same authentication steps as listed above, substituting the filenames above with the names of the files you just created.
This is a companion discussion topic for the original entry at https://www.qubes-os.org/news/2026/07/28/qsb-116/
So is this a VM escape? First time since 2006? Is there a PoC code?
2016, to my knowledge.
This bug, being the second critical bug in the Xen PV virtualization
(Quote from here)
This is not relevant for the current default on Qubes OS, which now relies on VT-d.
Moreover, this bug was the reason Qubes changed the default virtualization mode:
An observant reader will be quick to point out that it may have been a
mistake for Qubes to embrace paravirtualization (PV) as the default
mode of isolation.
Consequently, we have decided to move to hardware memory
virtualization for the upcoming Qubes 4.0 release [4].
You stated that it is “first time since 2006” (possibly). It is not.
You are technically right, but it is the first time for the relevant architecture. I only care about the security of the current Qubes implementation, not pure statistics.
Like bad oysters, bugs in Xen are better out than in.
@OvalZero @fsflover - thank you both for interesting and reassuring (*) background info!
* Reassuring because it’s so darned rare. So rare that you’re disagreeing about intervals of one or two decades. :slight_smile:
I wonder what can access grant tables from qube’s perspective. Can defence-in-depth stuff like passwordful root and MAC be used against this? Is mirage even capable of interacting with them?
I really meant to say:
Thank you to all who contributed to making that happen, especially @marmarek and all the qubes team.
(If an LLM was involved, I might even manage some grudging gratitude to whoever made that possible!)
I will post a simpler tutorial on how to reproduce this later. I tried to reproduce it myself and it almost crashed my qubes OS.
Is it so rare because there are so little exploitable bugs or is it so rare because Qubes/Xen is not as popular as other hypervisors/vmms and not enough security researchers/llms have been looking into it?
I have made several very uninteresting remarks about this question before (in this thread: Is using xen as the hypervisor makes as much sense now as it made before?)
There is also some related discussion in the interminable “Mythos” thread. I spare you from the link…
I know where my bet is, concerning the equation of
(number of hostile searchers × number of exploitable escape bugs) ÷ (number of friendly searchers)
I also know I could be wrong…
Although some parts are outdated, you might find the following document interesting:
I am on the -1 version. I saw in the UI updater there is no update, what do I do?? Also I have never been through a vulnerability of such scale, what happens next how do we know that all machines are not compromised?
Update I executed this command
sudo qubes-dom0-update --enablerepo=qubes-dom0-security-testing
To update the vulnerability please tell me if I did the right thing.
I’m running the new packages from security-testing on an AMD machine and everything seems to be working fine.
@Sks I used to use that command in older Qubes versions, but haven’t used it in a long time. Not sure if there are any issues with it. Now I go to Qubes Global Config, set the dom0 updates to enable security related testing updates and then use the UI updater to update dom0. That updated me to the 4.19.5-2 Xen packages.
Thanks for the answer, next time I shall use this method I guess it is better to use the testing update rather than have a zero day out in the wild. Now for the crazy card, how will we know if a system or computer has been breached by this vulnerability? Cause this is a real zero day, for all we know all computers with qubes are compromised?
As explained in the QSB, the packages containing the relevant security updates will migrate from the security-testing repository to the current (stable) repository over the next two weeks (from the QSB date) after being tested by the community. You can read more about testing updates here:
Now I’m thinking of Mythos topic here, and the guy with weird English talking about qubes escaping…
Hello, Just out of curiosity I ran the qubes updater today on dom0 and it indicated updating to xen 4.19.5-2 in the files being downloaded and updated and the updating did not show errors. However when I check xl info the info shows only 4.19.5. Is this reflecting someone just missing updating the version for the update to reflect the -2, or is the software not actually updated despite the file versions shown being updated through the updater as 5-2 ? The GUI of course reflects the same –not ver .5-2 I am using Qubes 4.3.1
Thanks!
