Note: A newer version of this QSB has been published. See Update for QSB-101: Register File Data Sampling (XSA-452) and Intel Processor Return Predictions Advisory (INTEL-SA-00982).
We have published Qubes Security Bulletin (QSB) 101: Register File Data Sampling (XSA-452). The text of this QSB and its accompanying cryptographic signatures are reproduced below. For an explanation of this announcement and instructions for authenticating this QSB, please see the end of this announcement.
Qubes Security Bulletin 101
---===[ Qubes Security Bulletin 101 ]===---
2024-03-12
User action
Continue to update normally [1] in order to receive the security updates
described in the "Patching" section below. No other user action is
required in response to this QSB.
Summary
On 2024-03-12, the Xen Project published XSA-452, "x86: Register File
Data Sampling" [3]:
| Intel have disclosed RFDS, Register File Data Sampling, affecting some
| Atom cores.
| This came from internal validation work. There is no information
| provided about how an attacker might go about inferring data from the
| register files.
For more details, see [4].
Impact
An attacker might be able to infer the contents of data held previously
in floating point, vector, and/or integer register files on the same
core, including data from a more privileged context.
Affected systems
At present, RFDS is known to affect only certain Atom cores from Intel.
Other Intel CPUs and CPUs from other hardware vendors are not known to
be affected.
RFDS affects Atom cores between the Goldmont and Gracemont
microarchitectures. This includes Alder Lake and Raptor Lake hybrid
client systems that have a mix of Gracemont and other types of cores.
Patching
The following packages contain security updates that address the
vulnerabilities described in this bulletin:
For Qubes 4.1, in dom0:
- Xen packages version 4.14.6-7
- microcode_ctl 2.1-57.qubes1
For Qubes 4.2, in dom0:
- Xen packages version 4.17.3-4
by the community. [2] Once available, the packages are to be installed
via the Qubes Update tool or its command-line equivalents. [1]
effect.
passphrase to new PCR values, as PCR18+19 will change due to the new
Xen binaries.
Credits
See the original Xen Security Advisory.
References
[1] https://www.qubes-os.org/doc/how-to-update/
[2] https://www.qubes-os.org/doc/testing/
[3] https://xenbits.xen.org/xsa/advisory-452.html
[4] https://www.intel.com/content/www/us/en/developer/articles/technical/software-security-guidance/advisory-guidance/register-file-data-sampling.html
The Qubes Security Team
Marek Marczykowski-Górecki’s PGP signature
-----BEGIN PGP SIGNATURE-----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=CgMr
-----END PGP SIGNATURE-----
Simon Gaiser (aka HW42)’s PGP signature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=XY1y
What is the purpose of this announcement?
The purpose of this announcement is to inform the Qubes community that a new Qubes security bulletin (QSB) has been published.
What is a Qubes security bulletin (QSB)?
A Qubes security bulletin (QSB) is a security announcement issued by the Qubes security team. A QSB typically provides a summary and impact analysis of one or more recently-discovered software vulnerabilities, including details about patching to address them. For a list of all QSBs, see Qubes security bulletins (QSBs).
Why should I care about QSBs?
QSBs tell you what actions you must take in order to protect yourself from recently-discovered security vulnerabilities. In most cases, security vulnerabilities are addressed by updating normally. However, in some cases, special user action is required. In all cases, the required actions are detailed in QSBs.
What are the PGP signatures that accompany QSBs?
A PGP signature is a cryptographic digital signature made in accordance with the OpenPGP standard. PGP signatures can be cryptographically verified with programs like GNU Privacy Guard (GPG). The Qubes security team cryptographically signs all QSBs so that Qubes users have a reliable way to check whether QSBs are genuine. The only way to be certain that a QSB is authentic is by verifying its PGP signatures.
Why should I care whether a QSB is authentic?
A forged QSB could deceive you into taking actions that adversely affect the security of your Qubes OS system, such as installing malware or making configuration changes that render your system vulnerable to attack. Falsified QSBs could sow fear, uncertainty, and doubt about the security of Qubes OS or the status of the Qubes OS Project.
How do I verify the PGP signatures on a QSB?
The following command-line instructions assume a Linux system with git and gpg installed. (For Windows and Mac options, see OpenPGP software.)
Obtain the Qubes Master Signing Key (QMSK), e.g.:
$ gpg --fetch-keys https://keys.qubes-os.org/keys/qubes-master-signing-key.asc gpg: directory '/home/user/.gnupg' created gpg: keybox '/home/user/.gnupg/pubring.kbx' created gpg: requesting key from 'https://keys.qubes-os.org/keys/qubes-master-signing-key.asc' gpg: /home/user/.gnupg/trustdb.gpg: trustdb created gpg: key DDFA1A3E36879494: public key "Qubes Master Signing Key" imported gpg: Total number processed: 1 gpg: imported: 1(For more ways to obtain the QMSK, see How to import and authenticate the Qubes Master Signing Key.)
View the fingerprint of the PGP key you just imported. (Note:
gpg>indicates a prompt inside of the GnuPG program. Type what appears after it when prompted.)$ gpg --edit-key 0x427F11FD0FAA4B080123F01CDDFA1A3E36879494 gpg (GnuPG) 2.2.27; Copyright (C) 2021 Free Software Foundation, Inc. This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. pub rsa4096/DDFA1A3E36879494 created: 2010-04-01 expires: never usage: SC trust: unknown validity: unknown [ unknown] (1). Qubes Master Signing Key gpg> fpr pub rsa4096/DDFA1A3E36879494 2010-04-01 Qubes Master Signing Key Primary key fingerprint: 427F 11FD 0FAA 4B08 0123 F01C DDFA 1A3E 3687 9494 -
Important: At this point, you still don’t know whether the key you just imported is the genuine QMSK or a forgery. In order for this entire procedure to provide meaningful security benefits, you must authenticate the QMSK out-of-band. Do not skip this step! The standard method is to obtain the QMSK fingerprint from multiple independent sources in several different ways and check to see whether they match the key you just imported. For more information, see How to import and authenticate the Qubes Master Signing Key.
Tip: After you have authenticated the QMSK out-of-band to your satisfaction, record the QMSK fingerprint in a safe place (or several) so that you don’t have to repeat this step in the future.
Once you are satisfied that you have the genuine QMSK, set its trust level to 5 (“ultimate”), then quit GnuPG with
q.gpg> trust pub rsa4096/DDFA1A3E36879494 created: 2010-04-01 expires: never usage: SC trust: unknown validity: unknown [ unknown] (1). Qubes Master Signing Key Please decide how far you trust this user to correctly verify other users' keys (by looking at passports, checking fingerprints from different sources, etc.) 1 = I don't know or won't say 2 = I do NOT trust 3 = I trust marginally 4 = I trust fully 5 = I trust ultimately m = back to the main menu Your decision? 5 Do you really want to set this key to ultimate trust? (y/N) y pub rsa4096/DDFA1A3E36879494 created: 2010-04-01 expires: never usage: SC trust: ultimate validity: unknown [ unknown] (1). Qubes Master Signing Key Please note that the shown key validity is not necessarily correct unless you restart the program. gpg> q -
Use Git to clone the qubes-secpack repo.
$ git clone https://github.com/QubesOS/qubes-secpack.git Cloning into 'qubes-secpack'... remote: Enumerating objects: 4065, done. remote: Counting objects: 100% (1474/1474), done. remote: Compressing objects: 100% (742/742), done. remote: Total 4065 (delta 743), reused 1413 (delta 731), pack-reused 2591 Receiving objects: 100% (4065/4065), 1.64 MiB | 2.53 MiB/s, done. Resolving deltas: 100% (1910/1910), done. -
Import the included PGP keys. (See our PGP key policies for important information about these keys.)
$ gpg --import qubes-secpack/keys/*/* gpg: key 063938BA42CFA724: public key "Marek Marczykowski-GĂłrecki (Qubes OS signing key)" imported gpg: qubes-secpack/keys/core-devs/retired: read error: Is a directory gpg: no valid OpenPGP data found. gpg: key 8C05216CE09C093C: 1 signature not checked due to a missing key gpg: key 8C05216CE09C093C: public key "HW42 (Qubes Signing Key)" imported gpg: key DA0434BC706E1FCF: public key "Simon Gaiser (Qubes OS signing key)" imported gpg: key 8CE137352A019A17: 2 signatures not checked due to missing keys gpg: key 8CE137352A019A17: public key "Andrew David Wong (Qubes Documentation Signing Key)" imported gpg: key AAA743B42FBC07A9: public key "Brennan Novak (Qubes Website & Documentation Signing)" imported gpg: key B6A0BB95CA74A5C3: public key "Joanna Rutkowska (Qubes Documentation Signing Key)" imported gpg: key F32894BE9684938A: public key "Marek Marczykowski-GĂłrecki (Qubes Documentation Signing Key)" imported gpg: key 6E7A27B909DAFB92: public key "Hakisho Nukama (Qubes Documentation Signing Key)" imported gpg: key 485C7504F27D0A72: 1 signature not checked due to a missing key gpg: key 485C7504F27D0A72: public key "Sven Semmler (Qubes Documentation Signing Key)" imported gpg: key BB52274595B71262: public key "unman (Qubes Documentation Signing Key)" imported gpg: key DC2F3678D272F2A8: 1 signature not checked due to a missing key gpg: key DC2F3678D272F2A8: public key "Wojtek Porczyk (Qubes OS documentation signing key)" imported gpg: key FD64F4F9E9720C4D: 1 signature not checked due to a missing key gpg: key FD64F4F9E9720C4D: public key "Zrubi (Qubes Documentation Signing Key)" imported gpg: key DDFA1A3E36879494: "Qubes Master Signing Key" not changed gpg: key 1848792F9E2795E9: public key "Qubes OS Release 4 Signing Key" imported gpg: qubes-secpack/keys/release-keys/retired: read error: Is a directory gpg: no valid OpenPGP data found. gpg: key D655A4F21830E06A: public key "Marek Marczykowski-GĂłrecki (Qubes security pack)" imported gpg: key ACC2602F3F48CB21: public key "Qubes OS Security Team" imported gpg: qubes-secpack/keys/security-team/retired: read error: Is a directory gpg: no valid OpenPGP data found. gpg: key 4AC18DE1112E1490: public key "Simon Gaiser (Qubes Security Pack signing key)" imported gpg: Total number processed: 17 gpg: imported: 16 gpg: unchanged: 1 gpg: marginals needed: 3 completes needed: 1 trust model: pgp gpg: depth: 0 valid: 1 signed: 6 trust: 0-, 0q, 0n, 0m, 0f, 1u gpg: depth: 1 valid: 6 signed: 0 trust: 6-, 0q, 0n, 0m, 0f, 0u -
Verify signed Git tags.
$ cd qubes-secpack/ $ git tag -v `git describe` object 266e14a6fae57c9a91362c9ac784d3a891f4d351 type commit tag marmarek_sec_266e14a6 tagger Marek Marczykowski-GĂłrecki 1677757924 +0100 Tag for commit 266e14a6fae57c9a91362c9ac784d3a891f4d351 gpg: Signature made Thu 02 Mar 2023 03:52:04 AM PST gpg: using RSA key 2D1771FE4D767EDC76B089FAD655A4F21830E06A gpg: Good signature from "Marek Marczykowski-GĂłrecki (Qubes security pack)" [full]The exact output will differ, but the final line should always start with
gpg: Good signature from...followed by an appropriate key. The[full]indicates full trust, which this key inherits in virtue of being validly signed by the QMSK. -
Verify PGP signatures, e.g.:
$ cd QSBs/ $ gpg --verify qsb-087-2022.txt.sig.marmarek qsb-087-2022.txt gpg: Signature made Wed 23 Nov 2022 04:05:51 AM PST gpg: using RSA key 2D1771FE4D767EDC76B089FAD655A4F21830E06A gpg: Good signature from "Marek Marczykowski-GĂłrecki (Qubes security pack)" [full] $ gpg --verify qsb-087-2022.txt.sig.simon qsb-087-2022.txt gpg: Signature made Wed 23 Nov 2022 03:50:42 AM PST gpg: using RSA key EA18E7F040C41DDAEFE9AA0F4AC18DE1112E1490 gpg: Good signature from "Simon Gaiser (Qubes Security Pack signing key)" [full] $ cd ../canaries/ $ gpg --verify canary-034-2023.txt.sig.marmarek canary-034-2023.txt gpg: Signature made Thu 02 Mar 2023 03:51:48 AM PST gpg: using RSA key 2D1771FE4D767EDC76B089FAD655A4F21830E06A gpg: Good signature from "Marek Marczykowski-GĂłrecki (Qubes security pack)" [full] $ gpg --verify canary-034-2023.txt.sig.simon canary-034-2023.txt gpg: Signature made Thu 02 Mar 2023 01:47:52 AM PST gpg: using RSA key EA18E7F040C41DDAEFE9AA0F4AC18DE1112E1490 gpg: Good signature from "Simon Gaiser (Qubes Security Pack signing key)" [full]Again, the exact output will differ, but the final line of output from each
gpg --verifycommand should always start withgpg: Good signature from...followed by an appropriate key.
For this announcement (QSB-101), the commands are:
$ gpg --verify qsb-101-2024.txt.sig.marmarek qsb-101-2024.txt
$ gpg --verify qsb-101-2024.txt.sig.simon qsb-101-2024.txt
You can also verify the signatures directly from this announcement in addition to or instead of verifying the files from the qubes-secpack. Simply copy and paste the QSB-101 text into a plain text file and do the same for both signature files. Then, perform the same authentication steps as listed above, substituting the filenames above with the names of the files you just created.
This is a companion discussion topic for the original entry at https://www.qubes-os.org/news/2024/03/13/qsb-101/
