We have just published Qubes Security Bulletin (QSB) 087: Qrexec: Injection of unsanitized data into log output. The text of this QSB is reproduced below. This QSB and its accompanying signatures will always be available in the Qubes Security Pack (qubes-secpack). More information about QSBs, including a complete historical list, is available here.
---===[ Qubes Security Bulletin 087 ]===---
2022-11-23
User action required
Users must install the following specific packages in order to address
the issues discussed in this bulletin:
For Qubes 4.1, in templates, standalones and dom0:
- qrexec packages version 4.1.19
by the community. [1] Once available, the packages are to be installed
via the Qubes Update tool or its command-line equivalents. [2]
Summary
Due to a bug in qrexec [3], a malicious qube that is allowed to call a
qrexec service inside of another qube can inject unsanitized data into
the log output of a process that handles incoming qrexec calls in the
receiving qube. This log output may end up in
`/var/log/qubes/qrexec.*.log`, `~/.xsession-errors`, or systemd's
journal.
Impact
An attacker could use this vulnerability in order to inject malicious
data, such as terminal control codes, into log output in the hope that
this data will be processed in a unsafe way, for example, by writing it
directly to a potentially-vulnerable terminal emulator.
In the default Qubes OS configuration, for example, there are qrexec
services like `qubes.WindowIconUpdater` that any qube can call in dom0.
An attacker who gains control of an untrusted qube could inject data
containing malicious terminal control sequences into
`/var/log/qubes/qrexec.*.log` in dom0. If the user views that log in a
terminal emulator in a way that doesn't filter terminal escape codes (by
simply using `cat` on the file, for example), the malicious data might
then exploit a hypothetical bug in the terminal emulator.
Note that this attack scenario, as described, has several layered
requirements:
1. The user must voluntarily open a log file containing malicious data
(or otherwise take action that causes the log file data to be
parsed).
2. There must exist an independent vulnerability in the user's terminal
emulator or in whichever program parses the log. (In other words, the
attacker must chain independent vulnerabilities together.)
3. If using a terminal emulator, a command-line tool that does not
filter control codes must be used. (`journalctl` prevents the display
of unsafe sequences by default, but many other tools do not.)
To be clear, the scenario in which the attacker uses the
`qubes.WindowIconUpdater` service in order to exploit a hypothetical bug
in a terminal emulator is just one conceivable scenario for how an
attacker might exploit the vulnerability described in this bulletin. It
is not the only way in which this vulnerability could be exploited, and
the requirements listed for this scenario may not necessarily apply to
other scenarios featuring different types of attacks (for example, using
other qrexec services and exploiting other software that handles log
output). Rather, this example is merely intended as an aid for
understanding the nature of the vulnerability.
Discussion
Qubes OS features a framework known as "qrexec," which allows different
qubes to communicate with each other in a controlled manner. [3][4]
These interactions are restricted by the system's RPC policies. [5] In
particular, qrexec can be used to allow less trusted qubes to
communicate with more trusted qubes, including dom0.
Normally, the calling side can send data to the remote services'
standard input and receive its standard output, standard error, and exit
code data. Since it handles untrusted data flows, qrexec is designed
under the assumption that an adversary will use it in order to launch an
attack against one qube from another qube. Therefore, qrexec treats
incoming data as untrusted and carefully sanitizes it. For example, when
qrexec output is connected to a terminal, `qrexec-client` and
`qrexec-client-vm` remove terminal control sequences.
However, due to a mistake in qrexec message type handling, the calling
side can send data marked as "standard error" (`MSG_DATA_STDERR`), and
the remote side will print it to the standard error of the process
handling incoming qrexec connections. This data flow was not expected.
Such messages should be rejected, as they are expected only in the other
direction. Consequently, this data is not appropriately sanitized, and
potentially-malicious data may end up in log output.
Credits
This issue was discovered by Demi Marie Obenour.
References
[1] https://www.qubes-os.org/doc/testing/
[2] https://www.qubes-os.org/doc/how-to-update/
[3] https://www.qubes-os.org/doc/qrexec/
[4] https://www.qubes-os.org/doc/qrexec-internals/
[5] https://www.qubes-os.org/doc/rpc-policy/
The Qubes Security Team
This is a companion discussion topic for the original entry at https://www.qubes-os.org/news/2022/11/23/qsb-087/
