We have just published Qubes Security Bulletin (QSB) 080: Issues with PV domains and PCI passthrough (XSA-401, XSA-402). The text of this QSB is reproduced below. This QSB and its accompanying signatures will always be available in the Qubes Security Pack (qubes-secpack).
View QSB-080 in the qubes-secpack:
https://github.com/QubesOS/qubes-secpack/blob/master/QSBs/qsb-080-2022.txt
In addition, you may wish to:
- Get the qubes-secpack: https://www.qubes-os.org/security/pack/
- View all past QSBs: https://www.qubes-os.org/security/qsb/
- View the XSA Tracker: https://www.qubes-os.org/security/xsa/
---===[ Qubes Security Bulletin 080 ]===---
2022-06-09
User action required
Users must install the following specific packages in order to address
the issues discussed in this bulletin:
For Qubes 4.0, in dom0:
- Xen packages, version 4.8.5-40
For Qubes 4.1, in dom0:
- Xen packages, version 4.14.5-2
by the community. [1] Once available, the packages are to be installed
via the Qubes Update tool or its command-line equivalents. [2]
effect.
passphrase to new PCR values, as PCR18+19 will change due to the new
Xen binaries.
Summary
The following security advisories were published on 2022-06-09:
XSA-401 [3] "x86 pv: Race condition in typeref acquisition":
| Xen maintains a type reference count for pages, in addition to a
| regular reference count. This scheme is used to maintain invariants
| required for Xen's safety, e.g. PV guests may not have direct
| writeable access to pagetables; updates need auditing by Xen.
| Unfortunately, the logic for acquiring a type reference has a race
| condition, whereby a safely TLB flush is issued too early and creates
| a window where the guest can re-establish the read/write mapping
| before writeability is prohibited.
XSA-402 [4] "x86 pv: Insufficient care with non-coherent mappings":
| Unfortunately, Xen's safety logic doesn't account for CPU-induced
| cache non-coherency; cases where the CPU can cause the content of the
| cache to be different to the content in main memory. In such cases,
| Xen's safety logic can incorrectly conclude that the contents of a
| page is safe.
Impact
These vulnerabilities, if exploited, could allow malicious PV domains
with assigned PCI devices to escalate their privileges to that of the
host. However, in the default Qubes OS configuration, these
vulnerabilities affect only the stubdomains for sys-net and sys-usb.
Therefore, in order to exploit these vulnerabilities in a default Qubes
installation, an adversary would first have to discover and exploit an
independent vulnerability in QEMU in order to gain control of an
appropriate stubdomain. Only after having done so would the adversary be
in a position to attempt to exploit the vulnerabilities discussed in
this bulletin.
XSA-402 affects only AMD systems and Intel systems before Ivy Bridge
(the third generation of the Intel Core processors). Newer Intel systems
are not affected.
Credits
See the original Xen Security Advisory.
References
[1] https://www.qubes-os.org/doc/testing/
[2] https://www.qubes-os.org/doc/how-to-update/
[3] https://xenbits.xen.org/xsa/advisory-401.html
[4] https://xenbits.xen.org/xsa/advisory-402.html
The Qubes Security Team
This is a companion discussion topic for the original entry at https://www.qubes-os.org/news/2022/06/09/qsb-080/
