We have just published Qubes Security Bulletin (QSB) 066: XML injection through libvirt domain configuration. The text of this QSB is reproduced below. This QSB and its accompanying signatures will always be available in the Qubes Security Pack (qubes-secpack).
View QSB-066 in the qubes-secpack:
https://github.com/QubesOS/qubes-secpack/blob/master/QSBs/qsb-066-2021.txt
Learn about the qubes-secpack, including how to obtain, verify, and read it:
https://www.qubes-os.org/security/pack/
View all past QSBs:
https://www.qubes-os.org/security/bulletins/
---===[ Qubes Security Bulletin 066 ]===---
2021-03-03
User action required
Users must install the following specific packages in order to address
the issues discussed in this bulletin:
For Qubes 4.0:
- qubes-core-dom0 package, version 4.0.58-1
For Qubes 4.1:
- qubes-core-dom0 package, version 4.1.20-1
The packages are to be installed in dom0 via the Qube Manager or via
the qubes-dom0-update command as follows:
For updates from the stable repository (not immediately available):
$ sudo qubes-dom0-update
For updates from the security-testing repository:
$ sudo qubes-dom0-update --enablerepo=qubes-dom0-security-testing
A system restart will be required afterwards. Alternatively, it is
possible to restart qubesd with the following command in dom0:
$ systemctl restart qubesd.service
by the community.
Summary
The libvirt domain configuration is an XML file built by filling a
template with values specific to a particular domain -- mostly its
properties but, in a few cases, "features" (extra properties that can be
freely defined). While most of the properties have strictly-defined
formats, some allow for a very broad range of values -- broad enough to
allow characters that are otherwise special in XML. Using such
characters in XML values requires escaping them, which was not enabled
in the template engine we use (jinja2). The specific VM metadata
properties that allow free text and are used in libvirt XML are as
follows:
- `kernelopts` property
- `timezone` feature (although it is validated in the template itself)
- `video-model` feature
- `audio-model` feature (Qubes R4.1 only)
Normally, this wouldn't be an issue, since all VM settings come from a
trusted entity (dom0). However, with the introduction of the Admin API
[1] in Qubes 4.0, it is possible to allow less trusted domains (known as
"ManagementVMs") to manage a subset of VMs or their settings, including
the affected properties and features. This, in turn, can be used to
modify unintended parts of the libvirt XML. In the worst case, this
could lead to code execution in dom0.
To fix the issue, we're enabling the autoescape feature of the jinja2
template engine. This will cover the current problematic properties as
well as any others that might be introduced in the future. Additionally,
we're adding an extra validation step for "features" that are otherwise
used in a free text form context (specifically, `net.fake-*` features
are expected to be IP addresses, but they lacked such validation).
Note that a ManagementVM can still break a VM it has control over, for
example, by setting some property to an improper value in a given
context (e.g., too little memory or too short of a startup timeout).
However, after these changes, it should no longer be able to escalate
its permissions beyond what it has been assigned.
Impact
Default Qubes 4.0 and 4.1 configurations are not affected.
If a less trusted domain (known as a "ManagementVM") is given Admin API
access to set any of the affected properties or features on any domain
(via the `admin.vm.property.Set` or `admin.vm.feature.Set` qrexec
services), it may use this access to elevate its privileges and
potentially take full control of the system.
Note that `qubes.FeaturesRequest` is enabled by default but *is not*
vulnerable for three reasons. First, feature names are read from
qubesd, which enforces a whitelist of permitted characters in paths.
None of the permitted characters are metacharacters in XML. Second,
none of the features for which dom0 will honor a request have their
values incorporated into libvirt XML. Third, `qubes.FeaturesRequest`
can only unset a feature or set its value to `1`.
Credits
This issue was discovered by Demi Marie Obenour.
References
[1] https://www.qubes-os.org/doc/admin-api/
The Qubes Security Team
This is a companion discussion topic for the original entry at https://www.qubes-os.org/news/2021/03/03/qsb-066/
