We have just published Qubes Security Bulletin (QSB) 065: Missed flush in XSA-321 backport (XSA-366). The text of this QSB is reproduced below. This QSB and its accompanying signatures will always be available in the Qubes Security Pack (qubes-secpack).
View QSB-065 in the qubes-secpack:
https://github.com/QubesOS/qubes-secpack/blob/master/QSBs/qsb-065-2021.txt
Learn about the qubes-secpack, including how to obtain, verify, and read it:
https://www.qubes-os.org/security/pack/
View all past QSBs:
https://www.qubes-os.org/security/bulletins/
View XSA-366 in the XSA Tracker:
https://www.qubes-os.org/security/xsa/#366
---===[ Qubes Security Bulletin 065 ]===---
2021-02-18
User action required
Users must install the following specific packages in order to address
the issues discussed in this bulletin:
For Qubes 4.0:
- Xen packages, versions 4.8.5-30
For Qubes 4.1: not affected
The packages are to be installed in dom0 via the Qube Manager or via
the qubes-dom0-update command as follows:
For updates from the stable repository (not immediately available):
$ sudo qubes-dom0-update
For updates from the security-testing repository:
$ sudo qubes-dom0-update --enablerepo=qubes-dom0-security-testing
A system restart will be required afterwards.
by the community.
passphrase to new PCR values, as PCR18+19 will change due to the new
Xen binaries.
Summary
On 2021-02-18, the Xen Security Team published the following Xen
Security Advisory (XSA):
XSA-366 [1] "missed flush in XSA-321 backport"
| An oversight was made when backporting XSA-320, leading entries in the
| IOMMU not being properly updated under certain circumstances.
Impact
XSA-366, as described by the Xen Security Team:
| A malicious guest may be able to retain read/write DMA access to
| frames returned to Xen's free pool, and later reused for another
| purpose. Host crashes (leading to a Denial of Service) and privilege
| escalation cannot be ruled out.
Credits
See the original Xen Security Advisory.
References
[1] https://xenbits.xen.org/xsa/advisory-366.html
The Qubes Security Team
This is a companion discussion topic for the original entry at https://www.qubes-os.org/news/2021/02/19/qsb-065/
