We have just published Qubes Security Bulletin (QSB) #061: Information leak via power sidechannel (XSA-351). The text of this QSB is reproduced below. This QSB and its accompanying signatures will always be available in the Qubes Security Pack (qubes-secpack).
View QSB #061 in the qubes-secpack:
https://github.com/QubesOS/qubes-secpack/blob/master/QSBs/qsb-061-2020.txt
Learn about the qubes-secpack, including how to obtain, verify, and read it:
https://www.qubes-os.org/security/pack/
View all past QSBs:
https://www.qubes-os.org/security/bulletins/
View XSA-351 in the XSA Tracker:
https://www.qubes-os.org/security/xsa/#351
---===[ Qubes Security Bulletin #61 ]===---
2020-11-10
Summary
On 2020-11-10, the Xen Security Team published Xen Security Advisory
351 (XSA-351) [1] with the following description:
| Researchers have demonstrated using software power/energy monitoring
| interfaces to create covert channels, and infer the operations/data used
| by other contexts within the system.
| Access to these interfaces should be restricted to privileged software,
| but it was found that Xen doesn't restrict access suitably, and the
| interfaces are accessible to all guests.
| For more information, see:
| https://platypusattack.com
| https://www.intel.com/content/www/us/en/security-center/advisory/intel-sa-00389.html
| An unprivileged guest administrator can sample platform power/energy
| data. This may be used to infer the operations/data used by other
| The research demonstrates using this sidechannel to leak the AES keys
| used elsewhere in the system.
Patching
The specific packages that resolve the problems discussed in this
bulletin are as follows:
For Qubes 4.0:
- Xen packages, version 4.8.5-26
For Qubes 4.1:
- Xen packages, version 4.14.0-7
The packages are to be installed in dom0 via the Qube Manager or via
the qubes-dom0-update command as follows:
For updates from the stable repository (not immediately available):
$ sudo qubes-dom0-update
For updates from the security-testing repository:
$ sudo qubes-dom0-update --enablerepo=qubes-dom0-security-testing
A system restart will be required afterwards.
by the community.
passphrase to new PCR values, as PCR18+19 will change due to the new
Xen binaries.
Credits
See the original Xen Security Advisory.
References
[1] https://xenbits.xen.org/xsa/advisory-351.html
The Qubes Security Team
This is a companion discussion topic for the original entry at https://www.qubes-os.org/news/2020/11/10/qsb-061/
