Hello
I am tired of writing again. But I have another problem
Problem
Today I booted my PC, wanted to start mu qubes but 2 of them gave me this error:
Error log
“Before is much more of it.”
[ 0.527309] registered taskstats version 1 [ 0.527329] Loading compiled-in X.509 certificates [ 0.550571] Loaded X.509 cert 'Build time autogenerated kernel key: 63059681e4d7909b71d012e028e683d213f22acd' [ 0.550644] zswap: loaded using pool lzo/zbud [ 0.551182] Key type ._fscrypt registered [ 0.551193] Key type .fscrypt registered [ 0.555972] Key type big_key registered [ 0.558022] Key type encrypted registered [ 0.558050] ima: No TPM chip found, activating TPM-bypass! [ 0.558092] ima: Allocated hash algorithm: sha256 [ 0.558113] ima: No architecture policies found [ 0.558312] xenbus_probe_frontend: Device with no driver: device/vbd/51712 [ 0.558330] xenbus_probe_frontend: Device with no driver: device/vbd/51728 [ 0.558347] xenbus_probe_frontend: Device with no driver: device/vbd/51744 [ 0.558364] xenbus_probe_frontend: Device with no driver: device/vbd/51760 [ 0.558381] xenbus_probe_frontend: Device with no driver: device/vif/0 [ 0.558411] hctosys: unable to open rtc device (rtc0) [ 0.558441] xen:balloon: Waiting for initial ballooning down having finished. [ 1.287505] xen:balloon: Initial ballooning down finished. [ 1.288569] Freeing unused decrypted memory: 2040K [ 1.289096] Freeing unused kernel image memory: 3016K [ 1.289268] Write protecting the kernel read-only data: 22528k [ 1.290375] Freeing unused kernel image memory: 2036K [ 1.290884] Freeing unused kernel image memory: 1640K [ 1.291053] rodata_test: all tests were successful [ 1.291066] Run /init as init process Qubes initramfs script here: [ 1.439552] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x22992ef9a56, max_idle_ns: 440795309370 ns [ 1.596615] blkfront: xvda: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; [ 1.629730] xvda: xvda1 xvda2 xvda3 [ 1.642609] blkfront: xvdb: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; [ 6.447503] xenbus_probe_frontend: Waiting for devices to initialise: 25s...20s...15s...10s...5s...0s...
End
I couldn’t find way to fix it, so I hope I will be able to fix it quickly with your help. Cheers.
