as far as I can see, not documented in --help, manpage or dev docs
Try qvm-ls --help-columns
that lists the fields, or columns. it doesn’t list what the flags the FLAGS column lists actually indicate. it only says they are “fancy”
I mean it’s documented?
What flags you have there ?
a, t, U, N, r, and more
ah i see, so that’s what you mean, check this :
Type of domain.
0 AdminVM (AKA Dom0)
aA AppVM
dD DisposableVM
sS StandaloneVM
tT TemplateVM
When it is HVM (optimised VM), the letter is capital.
type_codes = {
'AdminVM': '0',
'TemplateVM': 't',
'AppVM': 'a',
'StandaloneVM': 's',
'DispVM': 'd',
Current power state.
r running
t transient
p paused
s suspended
h halting
d dying
c crashed
? unknown
updateable = simple_flag(3, 'U', 'updateable',
doc='If the domain is updateable.')
provides_network = simple_flag(4, 'N', 'provides_network',
doc='If the domain provides network.')
installed_by_rpm = simple_flag(5, 'R', 'installed_by_rpm',
doc='If the domain is installed by RPM.')
internal = simple_flag(6, 'i', 'internal',
doc='If the domain is internal (not normally shown, no appmenus).')
debug = simple_flag(7, 'D', 'debug',
doc='If the domain is being debugged.')
autostart = simple_flag(8, 'A', 'autostart',
doc='If the domain is marked for autostart.')
[docs]
class FlagsColumn(Column):
'''Some fancy flags that describe general status of the domain.'''
# pylint: disable=no-self-use
def __init__(self):
super().__init__(head='FLAGS', doc=self.__class__.__doc__)
[docs]
@flag(1)
def type(self, vm):
https://dev.qubes-os.org/projects/core-admin-client/en/latest/_modules/qubesadmin/tools/qvm_ls.html
cheers
