Purism Librem Mini v1 [Merged #2]
layout:
  'hcl'
type:
  'desktop'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  'unknown'
remap:
  'yes'
brand: |
  Purism
model: |
  Librem Mini
bios: |
  4.18-Purism-1
cpu: |
  Intel(R) Core(TM) i7-8565U CPU @ 1.80GHz
cpu-short: |
  FIXME
chipset: |
  Intel Corporation Coffee Lake HOST and DRAM Controller [8086:3e34] (rev 0c)
chipset-short: |
  FIXME
gpu: |
  Intel Corporation WhiskeyLake-U GT2 [UHD Graphics 620] [8086:3ea0] (rev 02) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 07)
memory: |
  32643
scsi: |
usb: |
  1
versions:
- works:
    'FIXME:yes|no|partial'
  qubes: |
    R4.1
  xen: |
    4.14.5
  kernel: |
    5.15.76-1
  remark: |
    FIXME
  credit: |
    FIXAUTHOR
  link: |
    FIXLINK
Remarks
The Librem Mini V1 has the Intel 8650U chip. I was originally using Pureboot with the Librem Mini and every time I booted the machine I would have to regenerate the TOTP and reset TPM with 4.1. Also suspend never worked. So I reverted back to Coreboot. Suspend now works better. It crashes upon wakeup “only” 50 percent of the time now. It crashed upon Restore Backup the first time I attempted. I had to reboot the system. The second time I was able to restore without an issue. Everything else including the audio, ethernet, and usb ports appear to work fine. This is my report after several days of use. On a 1 to 10 scale of usability (10 being best) I would rate the machine a 7 with Qubes 4.1.
2 posts were merged into an existing topic: Purism Librem Mini v1
