Relatively novice Qubes user here. I am dealing with two problems that I presume are somehow related, but which have, in any case, both cropped up at the same time.
The first is that Tor is not working. I received the following error:
Tor is not running.
You have to fix this error, before you can use Tor.
Please restart after fixing this error.dom0 → Start Menu → ServiceVM: sys-whonix → Restart Tor GUI
or in Terminal:
sudo service tor@default restart
The first option, Restart Tor GUI, just brings up the same error. In the terminal, I get the following:
Redirecting to /bin/systemctl restart tor@default.service
Failed to restart tor@default.service: Unit tor@default.service not found.
Any advice appreciated.
The Qubes Update service indicates that debian-11 should be available for an update, but it fails consistently.
I fear I haven’t done enough searching of the forum to find out how to help myself, but I do feel a bit underwater currently.
