qqubes
1
Not sure if I should be making a bug report on this. Probably I will actually.
But I’ve seen the following two issues recur a number of times:
- When I try to start anon-whonix a popup with the following error appears:
Qube anon-whonix has failed to start: internal error: libxenlight failed to create new domain ‘anon-whonix’
- I can start anon-whonix, but it failes the connectivity test. Shutting down the qube and restarting it does not help.
The only way I know to fix either of these is to restart the computer.
Fails, as in, the Tor Browser times out in connecting websites?
qqubes
3
It does. But what I meant was the IP Check on the Whonix welcome page.
I have reported some similar issues in here:
qqubes
5
Interesting. I noticed that my padlock did have an X even though my connection seemed to be working fine.
I did a restart sdwdate and now the padlock is an O.
same here since several weeks. Looks like (my) sys-whonix/swdate always lost connection after a suspend and wakeup.
qqubes
7
I just got issue 2 again after a suspend/resume.
I made a bug report.
My sys-whonix is non-responsive after suspend, the workaround here fixed it:
