Problems Updating Fedora 32 template
Hello, for some weeks now I have been unable to successfully update the fedora 32 template.
If I update through Qubes updater it returns this: Rendering SLS ‘base:update.qubes-vm’ failed: jinja variable ‘dict object’ has no attribute ‘os’
If I update through the Qubes manager, using the blue arrow, it returns a series of errors related to pulse audio.
What do I do? I have been updating through the terminal but Qubes still tells me I need to update fedora 32.
Thanks in advance.
This is a known issue and there is a fix in testing. Personally I’m just ignoring the problem until the fix is released :slight_smile:
P.S. Don’t be tempted to try adding ‘–best --allowerasing’ options to the dnf command either, that will apparently kill your sound output.
