Problems Installing hplip
Hello,
I’m having problems getting hplip to work.
More specifically I have installed it on my debian template and it seems to have installed successfully. I tried to install it a second time and it told me nothing to installed, already got it. It also seems to be installed on the other debian qubes as I get the same message when I try to install it on specific qubes.
The problem is that it’s not in the applications menu in any qube in the settings or in any menu and I’m not sure what to do now.
When I had it in the previous version of qubes it installed with no issues and I had it pop up in the start bar etc.
Thanks in advance for any insights. I’ll be happy to provide any further information if asked
In order to get a GUI application, you have to install hplip-gui. Of the new applications it provides, you’re probably looking for HPLIP Toolbox.
Many thanks. I didn’t realise I needed another bit of software. Got it now and all is well, apart from feeling a bit of a moron :rofl:
