Printing in Qubes the easy way (USB needed)
If you’re new to Qubes and just want to print stuff, this is possibly the easiest way to do it, so long as you have a printer newer than 2015-ish and that has a USB port. If you don’t have one, see bellow for printer recommendations.
First Time Set Up
  1. Create qube
    • name: print
    • template debian-13-xfce (Debian 12 should fine as well)
    • applications: Thunar File Manager, Xfce4 Terminal and Print Settings (optional)
    • Launch qube setting after creation: :heavy_check_mark:
  2. Edit settings:
    • default disposable: none
    • services: cups and avahi (for this last one, you need to choose (custom) first)
  3. Open “Qube Manager” (you can search for it in the menu)
    • find print qube » right-click » “Run command in qube”: sudo mousepad /rw/config/rc.local (a text editor should show up)
  4. (In the text editor opened with the last command)
    • add to last line systemctl enable avahi-daemon
    • save
    • close window
Printing a File
  1. Right-click file » copy to other qube » print qube (as destination)
  2. Open file manager in print with: Q menu » print » Thunar File Manager
    • Choose Recents (left-hand side)
    • Double-click recently-copied file
    • Choose the print option OR Ctrl+p (may depend on viewer program)
  3. Attach printer USB device to print qube using the devices widget (top-right corner)
Auto-attaching: On Qubes 4.3+ you can auto-attach the printer USB device to the print qube.
  1. This is done in: Devices Widget » <YOUR_USB_PRINTER> » :gear: Device Settings » Auto-attach settings.
2 . “Device Assignment” » + Add new rule
  1. Choose between:
  • having a dedicated printer port (any other USB attached there will be auto-attached to the print qube) — generally safer, but can be more cumbersome if you have few ports
  • Memorize device identity — This one device will always be auto-attached, but a malicious device could trick the system into thinking it’s your printer and thus get auto-attached to the print qube
TODO clarify section by simply pointing to docs, once these are updated with 4.3 device management.
Troubleshooting / FAQ
TODO
Improvements (optional)
  • (TODO) Auto-open files when copied to print qube
  • (TODO) Disposable sys-print
    • Disclaimer: you won’t be able to save the settings
      • But you can change them if you edit the disposable template
    • set as the disposable
  • (Extra)
    • Shut down when idle
Wouldn’t making a permanent print port be moreso, though? A device wouldn’t even have to pretend to be the printer to get auto-attached, and if it did pretend, this wouldn’t be somehow safer if someone sticks a USB pretending to be your printer into your machine.
Or, do you mean a user attaching something malicious himself that pretends to be a printer without him being aware? Wouldn’t the user, in that case, easily see that a printer device appears in the USB menu when he inserted a flash dirve (or other USB)?
Could you clarify what you meant here?
Thanks for the feedback. I definitely need to clarify the text. You bring up some nuance that needs to be properly captured.
I think the best way is to just point to the docs on it, once they are updated for 4.3 and device handling.
