Potential of running Qubes on mini PCs
Hello everyone, i will be buying a mini PC in the next few weeks (Minisforum). Will QubesOS be able to run on these ok?
Search for “Minisforum” on this forum.
Hmm, i’ll by a car next week. Will i’m able to win the Indy500?
/jokes_off
Can you please be a little more detailed. They sell a lot of minicomputers, from low-end up to high-end.
And what exactly means “able to run”? Will you run two Qubes with 2 GB disk and 2GB RAM in parallel or 20 Qubes with 100 GB disk and 8 GB Ram at the same time?
A minisforum AI X1, I was wondering if there was any issues with installation.
It will be 32gb RAM.
What processor will you choose?
There are reports from other minisforum users in the HCL but not your
model. There can be issues with Ryzen processors - sometimes choosing
the latest kernel may help with this. Equally, there are folk with Ryzen
AI without issues.
I dont think any one can predict what will happen in the install.
It runs great on MS-01. You might have some issue with E cores but as far as I remember you might just need to disable E cores in the bios and that’s all.
