“Include in memory balancing” is enabled, I have rebooted the qube and the entire system multiple times but this issue persists. Cloning the qube, disabling Include in memory balancing, rebooting the qube, and re enabling it doesn’t fix the clone neither. Even with ample free memory available and opening many tabs and browsers, my Personal qube just slows down and stays stuck at whatever the initial memory set amount is. How can it be set to balance again?
You can change the amount of RAM allocated to the VM through Qubes Manager.
Looks to be Memory ballooning issue is back for the fedora-41 template · Issue #9663 · QubesOS/qubes-issues · GitHub
Yes, but that’s not the point. Having static memory usage is inefficient and defeats the purpose of the “include in memory balancing” feature which all qubes are supposed to offer.
That’s it. Thanks for sharing, hopefully it gets patched soon!
