How do i check if VT-d is enabled ? Can someone give me please cli commands? What does this message in the Dom0 log mean?
Greetings
alex
Greetings
alex
You can do a HCL-Report with qubes-hcl-report <vm-name> Where is the name of the vm where the report will be placed. If it says “IOMMU: YES” your VT-d is active.
If it does not, you have to check your bios to activate it.
