I’ve uploaded a new Parrot template to qubes.3isec.org.
You can grab it from there directly, or by adding that repository to
your system and using qvm-template.
Both are (sort of) documented here
The template is minimal core parrot.
You should be able to run tasksel as root, and select what classes of
tools you want to download and install.
