Panasonic Toughbook CF-54 MK2
layout:
  'hcl'
type:
  'laptop'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
remap:
  'yes'
brand: |
  Panasonic Corporation
model: |
  CF-54-2
bios: |
  V2.00L24
cpu: |
  Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz
cpu-short: |
  FIXME
chipset: |
  Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers [8086:1904] (rev 08)
chipset-short: |
  FIXME
gpu: |
  Intel Corporation HD Graphics 520 [8086:1916] (rev 07) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Intel Corporation Ethernet Connection I219-LM (rev 21)
  Intel Corporation Wireless 8260 (rev 3a)
memory: |
  16268
scsi: |
  DVDRAM GUD0N     Rev: PU01
  TOSHIBA THNSNJ25 Rev: 0101
usb: |
  1
versions:
- works:
    'FIXME:yes|no|partial'
  qubes: |
    R4.0
  xen: |
    4.8.5-35.fc25
  kernel: |
    5.4.143-1
  remark: |
    FIXME
  credit: |
    FIXAUTHOR
  link: |
    FIXLINK
Remarks
  • Installer worked with no tweaks for both UEFI and BIOS.
  • TPM works and can be re-owned by anti-evil-maid-tpm-setup
  • Wifi, Ethernet, and Mobile broadband work after passing internal WWAN device from sys-usb to sys-net (tested with Verizon SIM).
  • No USB 2.0, couldn’t get anti-evil-maid on USB flash drive to work
Thank you @owl for your HCL report, which is now online.
Note to some users: CF-54 is a wide product spec and many sub devices have TPM 1.2 or TPM 2.0 firmware, depending on model.
TPM 1.2 example: https://memstarrugged.co.uk/product/cf-54-hd-semi-rugged-laptop/
TPM 2.0 example https://www.toughdepot.com/toughbook-cf-54/
AEM requires 1.2
note: on some chips it is possible to downgrade TPM firmware from 2.0 to 1.2 depending on manufacturer support. Or you could pitch in and make AEM compatible with 2.0?.
The tpm can be downgraded from 2.0 to 1.2 using the utility provided by Panasonic:
https://pc-dl.panasonic.co.jp/dl/docs/075133
Note that Panasonic recommends updating BIOS and EC firmware to their latest versions before performing the downgrade.
These utilities are all provided on Panasonic’s support website:
https://na.panasonic.com/us/support/toughbook-support-center#/computers;id=116/toughbook-54;id=11316;sid=NaN/bios-ec-and-firmware;id=002003
Based on my experience, you should temporarily install Windows 8.1 instead of Windows 10 to do these updates. While I did not have to downgrade the TPM on my unit (as it was already 1.2), my unit did have a TPM firmware update available. Due to changes in how the TPM is handled in Windows 10, I had to clear and then re-own the TPM using the tpm.msc program built into windows 8.1. Make sure to backup the owner password at the end of the ownership process (as the update utility will ask for it) and then run Panasonic’s firmware update utility.
