Onion address for Qubes Community Forum?
Perfect shouldn’t be the enemy of good.
You could just run an nginx reverse proxy to onion that proxies the forum, kinda like EOTK does, while the forum is still hosted by Discourse. While not a perfect solution, it’s still an improvement in the meantime that the forum is still hosted by Discourse.
It can easily be done. I have made a proof of concept onion address for the forum:
It is an onion service that I run that acts as a clearnet proxy (with HTTPS, of course) to https://forum.qubes-os.org.
However:
  • It is REALLY slow
  • Because onion services do not use SSL, if the forum redirects you to anything that throws an error, check the address bar, and then change the https:// to http://, and try again, and it should load.
Because I don’t have direct access to the box running this forum, I am forced to decrypt web requests made to my hidden service, encapsulate them into HTTPS requests, and then forward them to the forum as if they were my own.
http://qubesospplmo4oyvn5fo5ykp3ga5dbkxar5c6prj5lvkgcwtg4ufrqid.onion/
This onion address is for viewing only
DO NOT LOG IN USING THIS ONION ADDRESS
I can see EVERYTHING
…including usernames and passwords in POST requests
I don’t keep logs, but even so, I just don’t want your information…
I would actually prefer whatever box this forum is running on to do all of this itself, but I don’t have access to it.
Happy to go through with the forum admins on how to get it done. It’s literally 30 seconds of work :slight_smile:
I’m failing to understand what advantage this brings over
straightforward https over Tor.
I think what was wanted was full access to the Forum via an onion site.
Honestly, if you get lucky with your exit node, there isn’t any, really. And the Qubes forum doesn’t exactly need to hide itself like some onion services, either.
The forum admins don’t have access to the box this forum is running on either. In fact, no one at the Qubes OS Project does. It’s hosted by a third-party service provider:
https://forum.qubes-os.org/privacy
Well that settles it, then. Case closed.
15 posts were split to a new topic: Tor Onion Service Security
If I access this forum’s clearnet address on Tor Browser I have to use exit nodes. Exit nodes are pesky. There have been different forms of attack vectors with them on the https encryption in the past, afaik.
On the other hand, using the onion address of this forum on tor browser doesn’t make me use exit nodes. All my connections stay inside tor network encrypted and anonymized.
There’s nothing like partial quotation to hide meaning. I dont
understand why it is so prevalent in these threads on privacy.
What you have quoted was part of my comment on the proposal to provide
“an onion service that I run that acts as a clearnet proxy (with HTTPS,
of course) to the Forum”.
I explicitly said that what was wanted was “full access to the Forum via
an onion site”.
yeah alright, I was skimming through the thread – I had no intention to hide meaning or whatsoever, just wanted to reply to your specific phrase
Thanks for your generous response to my message. I’m having a difficult
evening.
no probs, understandable, I could’ve been more cordial as well.
I suppose it’s a bit off topic, but why isn’t the Qubes Forum available under Onion?
Take a look at the lengthy thread -" Onion address for Qubes Community Forum?" in
Forum feedback
