Hi all,
Using Qubes OS 4.3.1, I am happy with the fedora-44-xfce template.
Is it ok to switch default-mgmt-dvm to fedora-44-xfce or do you advise to wait?
Thanks @DVM, @Droplet6200 & @sweet.cheddar for that topic on How to change default-mgmt-dvm template? .
Cheers,
I’m not sure what you mean by ‘is OK’, but I switched over in early May and haven’t looked back since. It just works.
It is Qubes OS: you can do the switch and go back to the previous template if there is any issue
If you really want to be sure, check the issue tracker:
Good to know, indeed.
Reminder that it only tells if someone has reported an issue…
Taking into account that many people do not have an account in Microsoft Github, and will never do.
They are living in the “Light Side”… (As far as possible, since it’s getting harder and harder: I’m 50+ and can tell you: it was as simple as that in the “world before”.
Thanks all for your answers.
It works fine!
Although we know it, it’s still a bit frightening when it’s your first time.
Thanks a lot for you whole answer.
Cheers,
If there is any serious issue it will be mentioned on the forum, the mailing list, the matrix channel or somewhere else and it will end up in Github.
