Hi yesterday i found out that my fedora 38 template is OBSOLETE and now it won’t get any new updates so i would like to ask what can i do to get the new template of fedora maybe 40 if it is possible, is there any documentation for such a scenario and where can i get a new template?
You can use Qubes Template Manager GUI tool to install new template and then switch your qubes to use the new template after installing it:
Thanks so much for the docs ![]()
