Nvme0: controller is down under load Q4.2.4 [SOLVED]
nvme nvme0: controller is down; will reset: CSTS=0xffffffff, PCI_STATUS=Ox11
nvme nvme0: Does your device have a faulty power saving mode enabled?
nvme nvme0: Try “nvme_core.default_ps_max_latency_us=0
nvme 0000:03:00.0: enabling device (0000 → 0002)
cie_aspm=off pcie port pmsoff” and eport al
xen: registering gsi 46 triggering 0 polarity 1
Already setup the GSI :46
nvme nvme0: Disabling device after reset failure: -19
When it happens, all Qubes are killed and dom0 becomes non-operational. I run mostly stock BIOS settings and had no issues before. It occurs under load—when I run many qubes or perform updates. I’ve tried different SSD slots and multiple restarts.
Resetting bios resolved the issue
