I installed the nvdia driver in dom0. Now how do I run games?
first, there will no 3d acceleration outside dom0, so playing game is not a good idea
also you shouldn’t run anything in dom0
anyway, if accept the risk, what game you what to play
Are there any way of checking hash or signature of NVIDIA drivers?
Why do you add rd.driver.blacklist=nouveau and disable it in 11? If you install the driver, you want to use it, but now you diable it.
nouveau is the open-source driver, you need to disable it to be able to use the driver from nvidia
Are there two drivers for Nvidia cards? One is nouveau and the other is from Nividia website like NVIDIA-Linux-x86_64-460.67.run?
nouveau is a free and open-source graphics device driver for Nvidia video cards
Yes, it’s two different drivers.
Have error for 5.10.90 kernel. I didn’t install 5.9.14 kernel you mentioned because I think 5.10 is greater than it.
This command succeeded qubes-dom0-update gcc kmod grub2-tools perl-bignum make
$ sudo make module IGNORE_XEN_PRESENCE=y CC="gcc -DNV_VMAP_4_PRESENT -DNV_SIGNAL_STRUCT_RLIM"
make: *** No rule to make target 'module'. Stop.
But isn’t a bad idea to build software on Dom0?
(Genuine question, I have 0 idea about it and I’m also having trouble with drivers.)
Best regards,
- me.
I installed my Nvidia drivers (I think) I used NVIDIA_Linux_x86_64-515.57.run . It installed perfectly with no errors, it asked me to modify the xorg. I selected yes. No errors at all…
but… Step 6 doesn’t work for me
Hi, at point 6 I got an error.
[user@dom0 kernel]$ sudo make module IGNORE_XEN_PRESENCE=y CC="gcc -DNV_VMAP_4_PRESENT -DNV_SIGNAL_STRUCT_RLIM"
make[1]: *** /lib/modules/6.3.9-1.qubes.fc32.x86_64/build: No such file or directory. Stop.
make: *** [Makefile:80: modules] Error 2
then I checked
[user@dom0 kernel]$ uname -r
[user@dom0 kernel]$ ll /lib/modules
total 12
drwxr-xr-x 7 root root 4096 May 23 18:20 5.15.94-1.qubes.fc32.x86_64
drwxr-xr-x 7 root root 4096 Jul 14 10:51 6.1.35-1.qubes.fc32.x86_64
drwxr-xr-x 7 root root 4096 Jul 15 14:21 6.3.9-1.qubes.fc32.x86_64
[user@dom0 kernel]$ ll /lib/modules/6.3.9-1.qubes.fc32.x86_64/
total 5220
lrwxrwxrwx 1 root root 42 Jun 22 05:00 build -> /usr/src/kernels/6.3.9-1.qubes.fc32.x86_64
drwxr-xr-x 2 root root 4096 Jun 22 05:00 extra
drwxr-xr-x 13 root root 4096 Jul 14 10:03 kernel
-rw-r--r-- 1 root root 1260528 Jul 15 14:21 modules.alias
-rw-r--r-- 1 root root 1235756 Jul 15 14:21 modules.alias.bin
-rw-r--r-- 1 root root 1557 Jun 22 05:00 modules.block
-rw-r--r-- 1 root root 11399 Jun 22 05:00 modules.builtin
-rw-r--r-- 1 root root 31759 Jul 15 14:21 modules.builtin.alias.bin
-rw-r--r-- 1 root root 14385 Jul 15 14:21 modules.builtin.bin
-rw-r--r-- 1 root root 91905 Jun 22 05:00 modules.builtin.modinfo
-rw-r--r-- 1 root root 507325 Jul 15 14:21 modules.dep
-rw-r--r-- 1 root root 698297 Jul 15 14:21 modules.dep.bin
-rw-r--r-- 1 root root 375 Jul 15 14:21 modules.devname
-rw-r--r-- 1 root root 241 Jun 22 05:00 modules.drm
-rw-r--r-- 1 root root 34 Jun 22 05:00 modules.modesetting
-rw-r--r-- 1 root root 2282 Jun 22 05:00 modules.networking
-rw-r--r-- 1 root root 174089 Jun 22 05:00 modules.order
-rw-r--r-- 1 root root 1165 Jul 15 14:21 modules.softdep
-rw-r--r-- 1 root root 569006 Jul 15 14:21 modules.symbols
-rw-r--r-- 1 root root 690937 Jul 15 14:21 modules.symbols.bin
lrwxrwxrwx 1 root root 5 Jun 22 05:00 source -> build
drwxr-xr-x 3 root root 4096 Jul 14 10:03 updates
drwxr-xr-x 3 root root 4096 Jul 14 10:03 vdso
drwxr-xr-x 2 root root 4096 Jun 22 05:00 weak-updates
[user@dom0 kernel]$ ll /usr/src/kernels/
total 8
drwxr-xr-x 23 root root 4096 May 23 18:16 5.15.94-1.qubes.fc32.x86_64
drwxr-xr-x 24 root root 4096 Jul 6 11:26 6.1.35-1.qubes.fc32.x86_64
I know this is a slightly older thread, so hope I can ask for some help.
Relatively new Qubes user & am having bad jerky video playback if viewing youtube or even gifs in “personal” qube.
Can someone please advise on how to get Nvidia working?
Specs are: Laptop
M7-12R5N5-668: Infinity M7 - 17.3, i5, RTX 3050 4GB graphics
RAM (memory): 32GB DDR4 3200Mhz RAM (2 x 16GB)
M.2 SSD slot 1 PCIe Gen4: 512GB PCIe Gen4 SSD (Solid State Drive)
Graphics: NVIDIA GeForce RTX 3050 with 4GB GDDR6 graphics
