layout:
'hcl'
type:
'Notebook'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'2.0'
remap:
'yes'
brand: |
Novacustom
model: |
V54x_6x_TU
bios: |
Dasharo (coreboot+heads) v0.9.0
cpu: |
Intel(R) Core(TM) Ultra 7 155H
cpu-short: |
chipset: |
Intel Corporation Meteor Lake-H 6p+8e cores Host Bridge/DRAM Controller [8086:7d01] (rev 04)
chipset-short: |
gpu: |
Intel Corporation Meteor Lake-P [Intel Arc Graphics] [8086:7d55] (rev 08) (prog-if 00 [VGA controller])
gpu-short: |
network: |
Intel Corporation Meteor Lake-P Gaussian & Neural-Network Accelerator [8086:7e4c] (rev 20)
7e4c]
Intel Corporation Device [8086:550a] (rev 20)
Intel Corporation Wi-Fi 7(802.11be) AX1775*/AX1790*/BE20*/BE401/BE1750* 2x2 [8086:272b] (rev 1a)
memory: |
65175
scsi: |
usb: |
5
certified:
'yes'
versions:
- works:
'yes'
qubes: |
R4.3-alpha
xen: |
4.19.2
kernel: |
6.15.7-1
remark: |
FIXME
credit: |
@kenosen
link: |
https://forum.qubes-os.org/t/novacustom-v54-series-v540tu-dasharo-coreboot-uefi-r4-3-alpha/35072
Remarks
Everything seems to be working, including suspend. I opted for the 2.8k screen which is not officially recommended by Novacustom for Qubes users (to say nothing of 4.3 being supported or encouraged … yet).
To get screen resolutions back (there was only one, making it difficult to read anything), follow the following instructions:
Modified edid: https://github.com/user-attachments/files/17007509/edid.zip
If you want to verify it, the sha256sum of the bin file is: 07393931ef6a7f2538fba3be242c6b1cca2e9d3bf0f50f0772d61ccb63df8e7a edid_v540tu_rangeonly60.bin
- Take the edid bin file and copy to
/lib/firmware/edid(create the dir in dom0) - Add
drm.edid_firmware=eDP-1:edid/edid_v540tu_rangeonly60.binto linux options (/etc/default/grub) - Regenerate grub config:
grub2-mkconfig -o /boot/grub2/grub.cfg - Create
/etc/dracut.conf.d/edid.confwithinstall_items+=" /lib/firmware/edid/* "
NOTE: Be careful about spaces - do exactly like the above - Regenerate initramfs:
dracut -f - Reboot
Now you should be able to set 2880x1800 with 120Hz and any other resolutions with 60Hz (some are listed also with other refresh rates, but those will not work).
