Hello,
Apologies in advanced if already reported, I am hesitant to post but did not find any issues describing what I am experiencing exactly.
I am having difficulty with notifications for some apps taking over control of my PS/2 Keyboard input when they window is collapsed. This can sometimes happen automatically, and others only when I click the notifications’ interaction button.
For example, Discord will send chat notifications with a simple “View” button, which users can click to launch the app/view the message.
When I have the Discord window collapsed (not closed or minimized, collapsed), notifications will inturrupt my keyboard input, leaving me to locate which of the many collapsed windows is currently holding my keyboard input hostage.
Notably, interacting with my original/main window does not reassign the cursor back to original window – I must instead manually locate the app currently in control of input, click the text input field, and then go back to my original window before my keyboard will work again.
This is especially frustrating when I have multiple apps open as it is not always obvious which app currently has control.
This is also posing some security risks, as my keyboard input is being passed without my knowledge to another qube & is sometimes causing me to start plaintext typing my usernames & passwords.
As is it likely relevant, I am also using a Security key which registers as a HID input device.
Please let me know if this is intended behavior, if I am misunderstanding something about procedure, or where to appropriately post this if necessary.
Thank you very much.
