I’ve noticed there are two domains I’ve not seen before on my machine. This seems a bit suspect, but I hope someone can provide an explanation.
While running xentop, I noticed a new domain called sys-net-dm. This domain does not show up in qvm-ls.
A new domain showed up in qvm-ls, called default-mgmt-dvm. It was not there until recently.
The two domain are probably unrelated to each other, except for the fact they both appeared seemingly out of nowhere. I’ve not seen them before and I definitely don’t remember creating them.
Does anybody know what they are? Are they created automatically by qubesOS? It’s very strange that I can’t find any reference online about sys-net-dm. I’m using Qubes R4.2.
A qube name with the suffix -dm seems to indicate an internal Xen convention when hardware is attached to a qube. Maybe it stands for device management. I have it this for sys-usb and sys-net
Each HVM qube runs with a stub domain attached. The stub domain is used for PCI device management, as well as for qrexec and audio support for non-Qubes integrated systems. There is a part about it in the Xen documentation: https://wiki.xenproject.org/wiki/Linux_stub_domains
There is also some information in the Qubes documentation:
You can verify this by comparing the ID you get with xl list sys-net-dm and qvm-prefs sys-net stubdom_xid.
That’s fantastic, thanks for clearing that up! I just realized sys-net-dm appeared after I issued speaker-test in sys-net (I was in the middle of some troubleshooting and it was the first domain I could think of to do this in).
