Hello guys so ive installed Qubes 4.3.1 im finding the wireless card im connecting it from sys-usb to to sys-net i check i see the network manager service is working im also restarting it and notification appear ( disconectected for connection something like that ) but i still cannot see the icon to connect to wifi
i think im missing iwlwifi but cannot install it cause i dont have neither ethernet nor wif
im using fedora as a VM template i changed to debian and tried Installing firmware-iwlwifi from bookworm-backports but nothing
What’s your WiFI controller model (VID:PID)?
Check the output of this command in sys-net with WiFI controller attached to it if it’s PCI controller:
lspci -nn
The device VID:PID would be at the end of the line in brackets [VID:PID].
Or if it’s USB device:
lsusb
