I’m trying to connect to WiFi using sys-net settings but I can see nothing but «VPN» and «Network proxy» in Network tab. How can I fix it? Are there any other ways to connect to WiFi?
Thanks for your time
Only works with Gnome-based vm template-based qube
Thank you for your answer! I don’t get how to connect to WiFi then
Could you please explain in to me?
Sorry for being stupid, I’m a total beginner
If you run in a Fedora template, it should work. If it doesn’t, try to reboot or sudo systemctl restart NetworkManager.
If you use a debian template, you might have to install the wifi drivers in your template first (usually iwlwifi or so).
@HPOA909, it sound potentially like your wifi hardware is either faulty, not detected, or missing firmware.
There is also something weird going on with Intel’s iwlwifi firmware inside Qubes VMs and the latest kernel build involving the AX210 chips from Intel.
Would you be able to open a sys-net terminal and type the following commands:
lspci -k
lsusb
lsmod | grep wifi
and post the output here?
This will:
sys-net (if your wifi card is built-in)sys-net (in case it’s a wifi dongle)Feel free to redact any information you like from the output (serial numbers, PCI ID numbers, etc.) if you feel the need for it. If you’ve redacted something that is actually relevant information, we’ll let you know
Once we know that, we can start ruling out some things, and get your wifi working
Depending on the hardware, it could be the kernel version you’re using.
