no wifi available since DOM0 upgrade
Ethernet Network shows disconnected.
fedora 43 used as template. also tried Debian 13.
lspci shows Network Controller Raptor Lake PCH CNVi wifi
Ethernet Controller are present
tried different kernels
If you have an external wireless adapter try clicking the qubes devices icon at the top right next to the icon for the wifi connection and find your adapter under the other tab hover over it and connect it to sys-net
no such luck with an external wireless adapter
thanks anyway
should have said do not have one
I resolve, it doing sys-net disposable, and reboot
in extreme case new installation and by
Main configuration
make sys-net disposable
sys-net is already a disposable vm. Using default-dvm as a template. I have tried both debian 13 and fedora 43 as templates for default-dvm.
sys-firewall and sys-usb are also disposables using default-dvm. Since this problem arose sys-usb is slow to start.
Solved the problem by opening the laptop and giving it a good cleaning.
Thanking all
