why can’t sys-usb be created with sudo qubesctl state.sls qvm-sys-usb?
and why isn’t yubikey installable in dom0
Maybe because you’re using USB keyboard and have only one USB controller:
installed yubikey
no USB keyboard and two different controller
Did you mistyped when you posted here or did you try this command?
The command should be this:
sudo qubesctl state.sls qvm.sys-usb
Also what error do you get when you run it?
I did an update manually and I typed qvm.sys-usb now it worked
