After a fresh install of Qubes OS, there are no network devices listed in the little networking icon in the top right of the screen. Looking at sys-net’s settings, it appears that the 2 ethernet adapters are correctly attached to it; one adapter should be connected to my home router and a device does show up from ip a within sys-net but there’s no internet connectivity.
I’m not sure how to start troubleshooting this. From other topics I’ve browsed, it could be an issue of missing drivers. At least, the driver for my ethernet devices should be bnx2 and lsmod | grep bnx2 from within sys-net outputs nothing. I’m not sure how to go about installing those drivers if so since there’s no internet connectivity to be used to download them. For debian it looks like they’re in the package firmware-bnx2. Would I need to manually download the .deb and install it on sys-net?
Is it an ip addr show in sys-net that shows an IP/subnet that matches your home router? What do you get with a
ip route show
in sys-net? - does that match your home router? If so, can you ping the IP of your home router from sys-net?
Of interest - and only slightly related to the topic: Did you only install “debian-12-xfce” … or did you also install “fedora-??-xfce” as template? If you also have a Fedora template, could you try starting sys-net based of Fedora?
Actually ip a doesn’t show an IP/subnet for my home network (10.0.0.0/24); it’s unreachable. I’m also now confused by the output of ip r since I don’t know where the one route came from. Please see the attached image.
I did try using the fedora template but there are still no network devices listed on the little red networking icon, and within it ip a only shows the loopback interface.
The vif3.0 you see, is the internal “device”, that eg. sys-firewall will connect to – if you run ip route show in a terminal from sys-firewall, I expect you’ll see something like:
default via 10.137.0.6 dev eth0 onlink
Could you try to run lspci in sys-net?
What do you get, if you run sudo dmesg -T | grep bnx in sys-net?
Unfortunately that yields no new info. After googling around it seems that at some point there could have been issues in fedora/debian with broadcom and tg3 modules being loaded in the wrong order or not at all, but I tried doing so manually and still get the same errors in dmesg output. If anyone runs into this issue, see this about broadcom adapters and hopefully that might lead you down a good track.
I ended up just buying a cheap realtek GbE adapter and whatever drivers in the debian template worked. Thanks for the help anyway.
Check lspci -k if there is any kernel module matching this device. If yes, look at dmesg more closely, maybe there is some driver error that didn’t match earlier grep you did. My guess would be some missing firmware.
But if no driver is listed in lspci -k output, try maybe different kernel version for sys-net, you can install kernel-latest-qubes-vm package in dom0 to have more options.
Generally, Broadcom is infamous for rather shitty Linux drivers, so the above might not help…
