Hi guys,
i tried to randomize my MAC address while scanning and connecting.
For this I use this how to https://www.qubes-os.org/doc/anonymizing-your-mac-address/
Every time I create this 00-macrandomize.conf in a template and then I use this for my sys-net or new NetVM´s. But after I can´t connect to my router. Both wifi and ethernet can´t build up a connection.
What I still notice is that my NetworkManager have very old versions. Partly 1.16 (fedora 30) and 1.22 (fedora 32). Every time I search for updates for these versions the already installed versions are shown as newest. The same applies to Gnome Network Manager.
So far I have done the following:
- build a new template
- create the 00-macrandomize.conf in the right place
- create a new NetVm or make sys-net to use the new template.
- restart all VM’s
- the network connections are tried to be established but cannot be connected.
What am I doing wrong? And if really necessary how exactly do I get the newer Network Manager versions?
Before I try this again I installed Qube’s OS 4.0.3 completely new and updated it.
And before the question comes… I absolutely need this for my work.
Thanks
