This is a search for “wl”. I’m guessing all this implies the driver isn’t compatible. A search for “network” returns three line errors related to network-proxy-setup.sh (can’t find gateway) but this is after the logging of the “wl” lines.
Sep 16 14:37:07 localhost systemd-journald[269]: Journal started
Sep 16 14:37:07 localhost systemd-journald[269]: Runtime Journal (/run/log/journal/0f0a229f278e4a478db22e547ea1c3a2) is 512.0K, max 3.3M, 2.8M free.
Sep 16 14:37:07 localhost systemd-modules-load[270]: Inserted module 'lp'
Sep 16 14:37:07 localhost systemd-modules-load[270]: Inserted module 'ppdev'
Sep 16 14:37:07 localhost systemd[1]: Started Journal Service.
Sep 16 14:37:07 localhost systemd-modules-load[270]: Inserted module 'parport_pc'
Sep 16 14:37:07 localhost systemd[1]: Starting Flush Journal to Persistent Storage…
Sep 16 14:37:07 localhost systemd[1]: Finished Helper to synchronize boot up for ifupdown.
Sep 16 14:37:07 localhost systemd[1]: Finished Create Static Device Nodes in /dev.
Sep 16 14:37:07 localhost systemd[1]: Reached target Local File Systems (Pre).
Sep 16 14:37:07 localhost systemd-journald[269]: Time spent on flushing to /var/log/journal/0f0a229f278e4a478db22e547ea1c3a2 is 48.611ms for 561 entries.
Sep 16 14:37:07 localhost systemd-journald[269]: System Journal (/var/log/journal/0f0a229f278e4a478db22e547ea1c3a2) is 64.0M, max 981.5M, 917.4M free.
Sep 16 14:37:08 localhost kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Sep 16 14:37:08 localhost kernel: cfg80211: Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
Sep 16 14:37:08 localhost kernel: cfg80211: Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
Sep 16 14:37:08 localhost kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Sep 16 14:37:08 localhost kernel: platform regulatory.0: firmware: direct-loading firmware regulatory.db
Sep 16 14:37:08 localhost kernel: platform regulatory.0: firmware: direct-loading firmware regulatory.db.p7s
Sep 16 14:37:08 localhost kernel: wl: loading out-of-tree module taints kernel.
Sep 16 14:37:08 localhost kernel: wl: module license 'MIXED/Proprietary' taints kernel.
Sep 16 14:37:08 localhost kernel: Disabling lock debugging due to kernel taint
Sep 16 14:37:08 localhost kernel: wl: module verification failed: signature and/or required key missing - tainting kernel
Sep 16 14:37:08 localhost kernel: xen: → pirq=17 → irq=40 (gsi=40)
Sep 16 14:37:08 localhost kernel: wl driver 6.30.223.271 (r587334) failed with code 1
Sep 16 14:37:08 localhost kernel: ERROR @wl_cfg80211_detach :
Sep 16 14:37:08 localhost kernel: NULL ndev->ieee80211ptr, unable to deref wl
Sep 16 14:37:08 localhost kernel: xen:xen_evtchn: Event-channel device installed
Sep 16 14:37:08 localhost kernel: memmap_init_zone_device initialised 32768 pages in 0ms
Sep 16 14:37:07 localhost systemd[1]: Starting Rule-based Manager for Device Events and Files…
Sep 16 14:37:08 localhost systemd-modules-load[270]: Inserted module 'wl'
Sep 16 14:37:08 localhost systemd-modules-load[270]: Inserted module 'xen_evtchn'
Sep 16 14:37:08 localhost systemd-modules-load[270]: Inserted module 'xen_blkback'
Sep 16 14:37:08 localhost systemd-modules-load[270]: Inserted module 'xen_gntalloc'
Sep 16 14:37:08 localhost systemd-modules-load[270]: Inserted module 'xen_gntdev'
Sep 16 14:37:08 localhost systemd-modules-load[270]: Inserted module 'u2mfn'
Sep 16 14:37:08 localhost systemd-modules-load[270]: Inserted module 'xen_netback'
Sep 16 14:37:08 localhost systemd[1]: Finished Load Kernel Modules.
