No disk space
I’ve used too much space and got error. I’ve cleaned data in qubes, so they use ~300gigs, but I still see warning that almost all space (403/406gb) is used. What to do?
Also I can’t decrease max storage size for qubes
okay, after I decided to create post, warning disappeared. Strange, because it persisted even after reboots.
Yeeez - whats your setup? 400G for Qubes is way too much.
Got no btrfs ref-link or lvm thin?
I’m having a similar problem. Normally, I should have 250 GB more free space, even though I’ve deleted quite a bit. The Recycle Bin is empty, too.
Personally, I would be struggling with 400GB on most of my machines. In my
experience users will fill any disks, whatever the size. I know people
with 2TB disks, and they still struggle.
But you can run Qubes in much smaller allocations. It just limits the
number of templates/qubes and (naturally) the amount of data you can
store.
If one is using that much memory on qubes, I think it is a misconfiguration.
Sure, if I would include my secondary storage into the calculation, I’d also need 2.65T on memory.
But only because I need 2.5T for non-qube data.
I believe most here are counting disk space - and not memory .. :wink:
I would agree, that 300Gb memory for Qubes OS, is probably a misconfiguration[1] .. and I recognize the statement from @unman, that I collect/keep files until I run out of space ..
:slight_smile:
[1]: .. or a very special use case!
I do not know what you mean to say.
We arent talking about memory here, but storage. Most users will not
have set up secondary storage, and will keep data within their qubes.
For those users it is not uncommon that they start to approach full
storage volumes as they store more and more data within their qubes.
If you mean to suggest that they should use secondary storage, well
OK, but that is not an option for many users. People use what they have.
I’m not a native speaker, but if you can’t make a sense out of that sentence, given the context … anyway
Thanks for sharing your personal situation regarding your storage needs, thank you.
Suggesting secondary storage, not at that point. I’d prefer to hear what OP has to say first. But sadly how someone else can live with 400G of storage is more important :slight_smile:
Again, I dont understand. Most consumer laptops come with 500GB to 1TB
disk space, with options for more. Dont you think that people will fill
that space? Why should Qubes users be any different?
I don’t care about your opinion since what I’ve already read from you.
I don’t care about what you think most people do with their system.
All I see is some “whatever”, stating generalizations in a user help thread, trying to argue and pick a fight.
If you at least understand what OP is saying, how about you responding to him.
Why? It’s just personal and work files
I’m assuming that this remark is aimed at balder86. Dont be concerned -
what you are doing is fine.
By default Qubes keep 2 back up copies of the private storage. This is
why when you delete files from a running system you dont immediately see
an overall saving.
You can see this by running qvm-volume info QUBE:private
If you only want one backup volume, set it like this:
qvm-volume set QUBE:private revisions_to_keep 1 : rebooting the qube
will delete one of the backups. For large data storage this is probably a
good idea.
Oh, you’re one of those people. Killfile.
Is there a way to trim disk space used by qubes? Sometimes after powering qubes off they do trim disks and I see more space in vm pool, but I’m not sure if it works after each power off
Is it possible to move selected qubes to separate disk? I want to add 1 more ssd to my laptop and offload some of qubes
I know I can mount another ssd as block device, but is keeping qubes on completely separate ssd possible?
