layout:
'hcl'
type:
'Desktop'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'unknown'
remap:
'yes'
brand: |
Nitrokey
model: |
NitroPC
bios: |
4.13-dirty
cpu: |
Intel(R) Core(TM) i7-10610U CPU @ 1.80GHz
cpu-short: |
FIXME
chipset: |
Intel Corporation Comet Lake-U v1 4c Host Bridge/DRAM Controller [8086:9b61] (rev 0c)
chipset-short: |
FIXME
gpu: |
Intel Corporation CometLake-U GT2 [UHD Graphics] [8086:9b41] (rev 02) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter [168c:003e] (rev 32)
Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 06)
memory: |
65409
scsi: |
usb: |
1
certified:
'no'
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.2.0
xen: |
4.17.2
kernel: |
6.1.62-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
Thanks for the HCL report. I just submitted a pull request to add it.
Thank you for HCL. Can you please also fill a detailed report based on this template:
Example of user providing the answers is here. The more information the better, it may be helpful to other users, thank you.
Installation
- no further special settings, cause Nitrokey shipped these models with open source Firmware/BIOS (Coreboot and Tianocore UEFI)
Basic Input
- USB Keyboard - works, after allowed to dom0
- External USB mouse [if possible to check] - works, after allowed to dom0
- creating sys-usb possible - works, but for known reason disabled during the install // have to be enabled by user
Internet and bluetooth
- Ethernet cable connection - works out of the box or actions were required
- Ethernet cable connection - speed - N/A
- Wifi connection - works out of the box or actions were required? - works
- Wifi connection - speed, is reliable over the time? - reliable
- Bluetooth - works out of the box or actions were required? - unknown
- Bluetooth - shows devices, connection process works, sound output or copying works.- unknown
Suspend
- Suspend/Resume works - works out of the box or actions were required? - untested
- Does resume breaks WiFi, if it does, how to recover it? - untested
- Does resume breaks Bluetooth, if it does, how to recover it? - untested
Video [increase VCPU to the qube before test]
- Fullscreen and windowed video playback of youtube - 720p/1080p/2K/4K in Firefox. Does it drop frames? - 720p/1080p/2160p works
- Video file playback of file using mpv/mplayer/smplayer - 1080p/2160p works
- Multiple displays configuration works? - works
Audio
- Speakers (sound playback) (was sys-audio used?) - works, no sys-audio used
- Head-phones via 3.5" jack (works, automatically turns off speakers?) - works/works
- Sound output via HDMI - works
- Audio-optical (S/PDIF) output - untested
Fans
- Are fans silent on idle? - often noisy
- Are fans noisier than on Windows/Linux? - not tested, but would say YES
Other
- Have you tried running Windows 10 HVM qubes? - yes, even Win11 works but untested on suspend
- Does CPU boost seem to be working properly? - unknown
Specs:
- (https://shop.nitrokey.com/shop/nitropc-1-132?search=nitropc#attr=225,229,239,237,244,245,247)
- 2160p
- 64GB Max Ram
- 1 USB Controller (assigned to sys-usb)
- Internal TPM - yes
