NiPoGi AK2 Plus
Remarks
Installation completed with error message ( Cannot connect to qrexec agent for 60 seconds, see /var/log/xen/console/guest-sys-net.log ). Module rtw88 must be blacklisted for sys-net and wifi driver compiled from tomaspinho/rtl8821ce @github. Default net qube cannot be changed: cloned sys-net to sys-net2, linked default ClockVM + VMs to it and deleted sys-net, then ran qubesctl state.apply qvm.sys-net to reinstall sys-net. Suspend works. Wired ethernet untested. 3,5" analog jack is a usb device and needs sys-audio (or modify sys-usb). No cpu/fan sensors only nvme. 9W in idle. All tested with kernel-latest.
layout:
  'hcl'
type:
  'Desktop'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  '2.0'
remap:
  'yes'
brand: |
  Default string
model: |
  Default string
bios: |
  5.26
cpu: |
  Intel(R) N100
cpu-short: |
  FIXME
chipset: |
  Intel Corporation Device [8086:461c]
chipset-short: |
  FIXME
gpu: |
  Intel Corporation Alder Lake-N [UHD Graphics] [8086:46d1] (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
  Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Network Adapter [10ec:c821]
  c821]
memory: |
  16159
scsi: |
  SanDisk SDSSDA-2 Rev: 40RL
usb: |
  1
certified:
  'no'
versions:
  - works:
      'FIXME:yes|no|partial'
    qubes: |
      R4.2.2
    xen: |
      4.17.4
    kernel: |
      6.10.3-1
    remark: |
      FIXME
    credit: |
      FIXAUTHOR
    link: |
      FIXLINK
Error message: “Cannot connect to qrexec agent for 60 seconds, see /var/log/xen/console/guest-sys-net.log” probably is caused by a wrong time/date and a general installation problem and not specific to this device. Set the correct time/date manually in the bios.
