Try to run the nextcloud client or the protonmail-bridge in a VM in 4.1. It closes all the windows open in the VM, and there’s no way to open any new windows, even using
$ qvm-run vm xterm
from dom0.
The VM remains running, however. I can kill the VM and restart it and open a terminal, but again, when running either of those two programs, it will crash heavily.
Here are logs from that vm (I called it “e”):
/var/log/xen/console/guest-e.log:
[2021-04-17 18:18:31] Fedora 33 (Thirty Three)
[2021-04-17 18:18:31] Kernel 5.10.28-1.fc32.qubes.x86_64 on an x86_64 (hvc0)
[2021-04-17 18:18:31] [press ENTER to login]
[2021-04-17 18:18:34] [ 12.593673] kauditd_printk_skb: 67 callbacks suppressed
[2021-04-17 18:18:34] [ 12.593675] audit: type=1130 audit(1618708714.505:79): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=systemd-hostnamed comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
[2021-04-17 18:18:35] [ 13.927666] audit: type=1106 audit(1618708715.838:80): pid=545 uid=0 auid=4294967295 ses=4294967295 msg=‘op=PAM:session_close grantors=pam_keyinit,pam_limits,pam_systemd,pam_unix,pam_umask,pam_lastlog acct=“user” exe="/usr/lib/qubes/qrexec-agent" hostname=? addr=? terminal=? res=success’
[2021-04-17 18:18:35] [ 13.927753] audit: type=1104 audit(1618708715.838:81): pid=545 uid=0 auid=4294967295 ses=4294967295 msg=‘op=PAM:setcred grantors=pam_rootok acct=“user” exe="/usr/lib/qubes/qrexec-agent" hostname=? addr=? terminal=? res=success’
[2021-04-17 18:18:36] [ 14.509350] audit: type=1130 audit(1618708716.421:82): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=polkit comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
[2021-04-17 18:18:36] [ 14.932644] audit: type=1106 audit(1618708716.843:83): pid=520 uid=0 auid=4294967295 ses=4294967295 msg=‘op=PAM:session_close grantors=pam_keyinit,pam_limits,pam_systemd,pam_unix,pam_umask,pam_lastlog acct=“user” exe="/usr/lib/qubes/qrexec-agent" hostname=? addr=? terminal=? res=success’
[2021-04-17 18:18:36] [ 14.932733] audit: type=1104 audit(1618708716.843:84): pid=520 uid=0 auid=4294967295 ses=4294967295 msg=‘op=PAM:setcred grantors=pam_rootok acct=“user” exe="/usr/lib/qubes/qrexec-agent" hostname=? addr=? terminal=? res=success’
[2021-04-17 18:18:36] [ 15.342683] audit: type=1130 audit(1618708717.254:85): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=rtkit-daemon comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
[2021-04-17 18:19:06] [ 45.075938] audit: type=1131 audit(1618708746.987:86): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=systemd-hostnamed comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
[2021-04-17 18:19:06] [ 45.096681] audit: type=1334 audit(1618708747.008:87): prog-id=24 op=UNLOAD
[2021-04-17 18:19:06] [ 45.096713] audit: type=1334 audit(1618708747.008:88): prog-id=23 op=UNLOAD
/var/log/qubes/guid.e.log:
Icon size: 128x128
ErrorHandler: BadValue (integer parameter out of range for operation)
Major opcode: 12 (X_ConfigureWindow)
Value: 0x0
Failed serial number: 1537
Current serial number: 1540
/var/log/qubes/qrexec.e.log:
Empty
Any hints on making this work?
