Network access with 802.1x certificat stored in TPMv2
Hello,
In my company, LAN access is controlled with 802.1x and machine certificate stored in TPMv2.
Does Qubes OS support this configuration ?
I do not see any vTPM support in sys-net …
Thanks
I do not think that sys-net will have access to TPM, but dom0 will.
You could,I think, read the certificates from TPM and copy them to
sys-net on startup, then configure the connection to access them locally.
Yes, but it is not the same level of security.
If the certificates is unprotected inside the untrusted sys-net filesystem, …
Does xen hypervisor offer virtualisation of TPM to other qubes ?
Any chance to have this feature in a next qubesOS release ?
