Hi, is there a latest kernel .iso for the stable Qubes 4.1.0?
I need the latest kernel stable build to install Qubes on my Alienware. Like these ones work: Index of /qubes/iso/
But theyre not the stable 4.1.0 build.
My specs are:
- 4k Monitor
- Intel i7 11800H Processor
- NVIDIA RTX 3070
- Intel UHD Graphics
Thank you! =)
I think no, but current-testing would be fine, and are you sure that even with the current testing your pc could run it ? fyi I’ve been using kernel-latest since 4.1 alpha, doesn’t have any major issue with it.
Ive updated my post for the specs of my laptop.
I get a pink screen after I choose install Qubes. 4.1.0.
Theres a warning that says to not use the dev build. So I was wondering if there was a kernel-latest version of 4.1.0 instead.
Thanks for your reply. ^^
