Hello. I have troubles with openvpn connection in Qubes. I need to use vpn on my server, so I rent VPS with Devuan (it’s Debian without systemd) , install openvpn and setup is with this script.
I copy config file on my android phone, and it just works.
On Qubes it doesn’t work, and I can’t understand why. I use debian 11 as sys-vpn
Previously I used commerical public vpn, and it worked without any troubles, it works now. With my config I have no connection. I tried to connect in sys-vpn with command sudo openvpn --config /rw/config/qtunnel/qtunnel.conf.
At start I have write udp: operation not permitted error, after entering
iptables -P OUTPUT ACCEPT
openvpn output looks like all is ok, but no connection.
qubes-tunnel.service shows xfce notification “Link is up!”. Ping doesn’t work, any webpage doesn’t load.
While I wrote text, I tried to restore previous configuration for public vpn with authorization by credentials and it works. When I restore my configuration that don’t require credentials, so in /rw/config/qtunnel/ I have qtunnel.conf and empty no-tunneluserpwd.txt files, openvpn output is:
root@sys-vpn-pers:/rw/config/qtunnel# openvpn --config qtunnel.conf
2022-11-26 16:37:28 OpenVPN 2.5.1 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on May 14 2021
2022-11-26 16:37:28 library versions: OpenSSL 1.1.1n 15 Mar 2022, LZO 2.10
2022-11-26 16:37:28 Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
2022-11-26 16:37:28 Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
2022-11-26 16:37:28 TCP/UDP: Preserving recently used remote address: [AF_INET]{hidden server ip}:1194
2022-11-26 16:37:28 Socket Buffers: R=[212992->212992] S=[212992->212992]
2022-11-26 16:37:28 UDP link local: (not bound)
2022-11-26 16:37:28 UDP link remote: [AF_INET]{hidden server ip}:1194
2022-11-26 16:37:28 write UDP: Operation not permitted (code=1)
2022-11-26 16:37:30 write UDP: Operation not permitted (code=1)
2022-11-26 16:37:34 write UDP: Operation not permitted (code=1)
2022-11-26 16:37:35 event_wait : Interrupted system call (code=4)
2022-11-26 16:37:35 SIGINT[hard,] received, process exiting
I think I need to fix iptables rules but i don’t know how. Please help me.
