I decided to try to install Qubes 4.3.0 from scratch rather than doing an in-place upgrade, as I have done so far. It seems more difficult than I expected. Maybe it is because it has been a few years since I installed for the first time.
I am facing the following challenges:
Whenever I try to unlock my existing luks volume (where I have 4.2.4 installed), the installer either makes me wait for several minutes or hangs for infinity, especially when using the “Blivet-GUI”.
I want to keep the current disk layout, but I can’t find a doc which explains how to preserve existing partition setup, and I am not much experienced with LVM. The automatic suggestion the installer gives me attempts to create sections on the drive and install the new system in the empty space that I have left for over provisioning. I don’t want that.
In 4.2.4 in /etc/fstab I have:
/dev/mapper/qubes_dom0-root / ext4 defaults,x-systemd.device-timeout=0,discard,noatime 1 1
UUID=... /boot ext4 defaults,discard,noatime 1 2
UUID=... /boot/efi vfat umask=0077,shortname=winnt,discard 0 2
/dev/mapper/qubes_dom0-swap none swap defaults,x-systemd.device-timeout=0 0 0
user@dom0:~ > lsblk -T /dev/nvme0n1 | head
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
nvme0n1 259:0 0 953.9G 0 disk
├─nvme0n1p1 259:1 0 600M 0 part /boot/efi
├─nvme0n1p2 259:2 0 1G 0 part /boot
└─nvme0n1p3 259:3 0 713.8G 0 part
└─luks-*** 253:0 0 713.8G 0 crypt
├─qubes_dom0-pool00_tmeta 253:1 0 88M 0 lvm
│ └─qubes_dom0-pool00-tpool 253:3 0 703.6G 0 lvm
│ ├─qubes_dom0-root 253:4 0 703.6G 0 lvm /
│ ├─qubes_dom0-pool00 253:6 0 703.6G 1 lvm
In the installer I see the /boot, /boot/efi but not / and swap, even if I am lucky to unlock the LUKS volume. So, I can’t simply say “Just use this existing section of my drive for this same purpose” for / and swap, as I would like.
- I have no idea what ‘PE’ to set whenever I am being offered to choose one.
I am basically lost.
Can someone please help?
