Named Disposable
tommy@dom0:\~$ qvm-shutdown --wait sys-usb ; qvm-prefs sys-usb template fedora-43-xfce ; qvm-start sys-usb ; sleep 3m ; qvm-shutdown --wait sys-usb ; qvm-prefs sys-usb template fedora-42-xfce ; qvm-start sys-usb
qvm-prefs: error: template for disposable must have template_for_dispvms=True
**qvm-prefs: error: template for disposable must have template_for_dispvms=True**
phceac returned this reply can anyone help me solve this issue?
Then there is a problem -I think- that your sys-usb is a “named disposable” qube, so it must have a template that is suitable. I do not remember the name of the setting to make your new template work…
Maybe someone else can help with that one…
A little more context/structured explanation would have been nice.
From what I can see, the message tells you to set template_for_dispvms=True.
So do it :stuck_out_tongue:
I’m using salt for config, I guess that does not apply to you.
Have a look at the docs here, they do not state template_for_dispvms but will propably work anyway.
Can you provide the output ofqvm-prefs sys-usb? I suspect your template is currently set as a disposable template rather than a regular template, which may be causing the issue.
Edit: I suspect your sys-usb is a disposable vm, in which case it cannot use a regular template as its template.
~$ qvm-prefs sys-usb
audiovm D dom0
auto_cleanup D False
autostart - True
backup_timestamp U
bootmode D default
debug D False
default_dispvm D default-dvm
default_user D user
devices_denied D
dispid - 5855
dns D 10.139.1.1 10.139.1.2
gateway D 10.138.23.13
gateway6 D
guivm D dom0
icon D servicevm-red
include_in_backups D True
installed_by_rpm D False
ip D 10.138.23.13
ip6 D
is_preload D False
kernel D 6.18.42-1.fc41
kernelopts D
keyboard_layout D us++
klass D DispVM
label - red
mac D 00:16:3e:5e:6c:00
management_dispvm D default-mgmt-dvm
maxmem - 0
memory - 300
name - sys-usb
netvm - None
provides_network - True
qid - 15
qrexec_timeout D 60
shutdown_timeout D 60
start_time D 1786892873.46
stubdom_mem U
stubdom_uuid D c6de2b9d-73a6-42b3-9ff6-737105e0e94a
stubdom_xid D 2
template - default-dvm
updateable D False
uuid - ba57a88c-5089-4451-8414-7d670013d854
vcpus D 2
virt_mode - hvm
visible_gateway D
visible_gateway6 D
visible_ip D 10.138.23.13
visible_ip6 D
visible_netmask D
xid D 1
I think @unman and you all missed the crucial part. It’s not
but
qvm-prefs default-dvm template fedora-43-xfce
@Tbone
That is part of the confusing terminology of Qubes: template ↔ disposable template.
Templates have property klass=TemplateVM.
Disposable templates are AppVMs (qubes based on a template) and have property template_for_dispvms=True.
Disposables (klass=DispVM) have their qvm-prefs template property set to an AppVM.
TemplateVM → AppVM → disposable
The error you are getting is due to the fact that fedora-43-xfce is a template (TemplateVM), not a disposable template (AppVM).
Assuming you already have an AppVM default-dvm based on a TemplateVM of your choice, replace in your commands:
with
qvm-prefs default-dvm template_for_dispvms True # Optional, if not already set
qvm-prefs sys-usb default-dvm
There are no assumptions there, or arrogance. Just repeating, for some reason, with more words, what I already wrote in my previous message.
By giving such a subject to a topic, it was obvious that the user already knows what their sys-usb is.
Off-topic
https://inv.nadeko.net/watch?v=UYpmSJ09hRc
OK I am confused my default-dvm is using the fedora-42 template, I want to change that to the default-dvm using fedora-43. uman suggested this:
qvm-shutdown sys-usb
qvm-start sys-usb
sleep 3m
qvm-start sys-usb
Would this be correct?
qvm-prefs default-dvm fedora-43-xfce True
qvm-start sub-usb
EDIT: Sorry, Now I see you asked other user.
I’m asking anybody he just replyed, can you tell me if those last 4 lines will work?
They wouldn’t. qvm-prefs default-dvm fedora-43-xfce True doesn’t make sense. Try this.
qvm-shutdown --all --wait
qvm-start sys-usb
sleep 3m
qvm-prefs default-dvm template fedora-42-xfce
qvm-start sys-usb
Either put the commands in a script and run it, or put all of them in a single line separated with semicolons (“;”). If the keyboard works after the first time sys-usb restarts, just press Ctrl+C to prevent reverting to the Fedora 42 template.
Don’t bring me in to this.
When I put forward that script, it was in a different context and it
worked
for the OP in that thread.
Obviously any contribution in the Forum must be reviewed and adapted to
the circumstances of the user.
This sets the template of AppVM named default-dvm to fedora-43-xfce:
You can restart sys-usb like this:
qvm-shutdown --wait sys-usb; sleep 1; qvm-start sys-usb
This shuts down sys-usb, waits 1 second, then starts it.
You can put this in a bash script and assign a shortcut key to run it - a convenience when using a USB keyboard.
