Hello,
I tried uninstalling and installing again sys-usb, just because it wasn’t detecting my printer that I bought.
After that, couldn’t really login into qubes again, my keyboard and mouse stopped working, everytime I login my computer I put command into grubloader qubes.skip_autostart Everytime I CTRL+SHIFT+C it copies my text, but it doesn’t paste between qubes, it shows that i copied for example 20 letters.
Please help me, I’m tired of this. How do I fix my keyboard and mouse, to function without the autostart command too
After doing the CTRL+SHIFT+C in source qube and confirming it is copied to Global Clipboard (the example 20 letters you mentioned), then in the destination qube, you have to press CTRL+SHIFT+V before actually pasting (e.g. with CTRL+V).
Check the Qubes Global Config → Clipboard tab, maybe you have a warning there or you changed the paste keyboard shortcut or added a custom policy.
Also run this command in dom0 terminal:
sudo journalctl -f -n0
And try copy/paste the text to/from global clipboard, then check if you’ll see any policy errors in the command output.
I ran this command, nothing actually happened, terminal was clear as it was before, then tried to copy paste with terminal opened, nothing happened at all too
